marcoh
Using PLL in Spartan 6 device
I've got a little question about the power supply for the Spartan 6 devices. Does I need a special supply for the PLL's or is the PLL powered by a standard supply? I've read the manuals, but I did not found this information.
My other problem is that I'm not sure whether I can route every global clock input internally to both of the two PLL's or do I need to use a special global clock input pin for a special PLL?
Thank you a lott for your help
Marco
austin
Marco,
No, the PLL is supplied from the exisiting power to the FPGA device.
Consult the user's guide for restrictions on clock pin placement vs. PLL location.
http://www.xilinx.com/support/documentation/user_guides/ug382.pdf
pg 109
Austin Lesea
Principal Engineer
Xilinx San Jose
eteam00
Professor
Professor
pg 109
I think the section to which Austin is referring is on page 106, not page 109.
Current UG382 is version 1.5
-- Bob Elkind
SIGNATURE:
Summary:
