02-02-2012 04:59 AM
I want to know the initial value of registers in FPGA device when power is on. And how to set it? In verilog/VHDL or ISE ?
02-02-2012 05:08 AM - edited 02-02-2012 05:31 AM
In the ISE Navigator shell, open up the Language Templates by clicking on the lightbulb icon.
Language Templates are listed for both VHDL and Verilog.
Using Verilog as an example, navigate through the Language Templates as follows:
Verilog > Synthesis Constructs > Signal, Constant, & Variable Declarations > Register > Initialized > Reg > 16-bit
And here is the template: reg [15:0] <name> = 16'h0000;
The assigned value can be any value which matches the width of the declared reg. The initialisation takes place as part of the FPGA configuration process. If your only need for a reset signal is to initialise state, use of the assigned initial value could remove the need for an instantiated reset in the design, which means fewer hardware resources used in your design.
Make sense? Have fun with the templates, they are very handy and informative.
-- Bob Elkind
-- Bob Elkind
02-02-2012 05:43 AM
02-02-2012 07:32 AM
Here's some more points:
When you don't give an initial value to a register by any other means it defaults to zero.
However in that case, your design will not match simulation, wich initialized the
registers to "unknown."
If a register has an asynchronous or synchronous reset as part of the behavioral
description, then the value it is assigned for reset will also be the initial value
of the register.
i.e.
reg [15:0] foo = 16'h1234; // Explicitly declared init value
or:
reg [16:0] foo; // no init value in the declaration
always @ (posedge clk or posedge rst)
if (rst) foo <= 16'h1234; // XST will use this as the init value
else foo <= bar;
or:
reg [16:0] foo;
initial foo = 16'h1234;
in all three cases foo will start up as 0x1234.
but:
reg [15:0] foo; // no init value declared
always @ (posedge clk) foo <= bar;
In this case foo will initialize to zero for synthesis, but to 16'hXXXX for simulation.
-- Gabor
02-02-2012 07:06 PM
