dimas_mmf
component dcm for frequensy division
I work for spartan 3a starter kit. The following program shows the Morse code on light bulbs my name and surname. With the help of dcm and multiplexer I want to switch to one of the frequency divided in half (from 50 MHz to 25 MHz). However, it turns out that the frequency is divided four times. How can I fix it? I would like to divide the frequency in half has been realized within the components.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
USE ieee.numeric_std.ALL;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity lab1 is
	Port (clk : in STD_LOGIC;
			en : in STD_LOGIC;
			en1 : in STD_LOGIC;
			en2 : in STD_LOGIC;
			en3 : in STD_LOGIC;
			LED : out std_logic_vector (7 downto 0));
end lab1;
architecture Behavioral of lab1 is
	signal COUNT_OUT : STD_LOGIC_VECTOR(26 downto 0) := (others => '0');
	signal name1 : std_logic_vector (0 to 60) := "1110101000111011100010100011100010111010001010001011101110111";
	signal name2 : std_logic_vector (0 to 66) := "1010100010111010101010001110100010001110100011101011100011101110111";
	signal name3 : std_logic_vector (0 to 76) := "10100011101110100011101110111000101110100010001011101110001010001110111011101";
	signal count : std_logic_vector (0 to 10) := (others => '0');
	signal temp : std_logic_vector (3 downto 0) := (others => '0');
	signal clk_new : std_logic := '0';
	signal clk_amount : integer := 50000000;
	signal state : integer := 0;
	COMPONENT my_dcm
		PORT (CLKDV_SELECT_IN : IN std_logic;
				CLKIN_IN: IN std_logic;
				CLKDV_OUT: OUT std_logic;
				CLKIN_IBUFG_OUT: OUT std_logic;
				CLK0_OUT: OUT std_logic);
	END COMPONENT;
begin
	Inst_my_dcm: my_dcm PORT MAP (CLKDV_SELECT_IN => en3,
				      CLKIN_IN => CLK,
				      CLKDV_OUT => clk_new,
				      CLKIN_IBUFG_OUT => open,
				      CLK0_OUT => open);
	process(en3)
	begin
		if(en3 = '1') then
			clk_amount <= 25000000;
		else
			clk_amount <= 50000000;
		end if;
	end process;
	process(clk_new)
	begin
		if rising_edge(clk_new) then
			if (en = '1' and en1 = '0' and en2 = '0') then
				if (conv_integer(COUNT_OUT) = clk_amount) then
					COUNT_OUT <= conv_std_logic_vector(0, 26);
					temp <= temp(2 downto 0) & name1(conv_integer(count));
					LED(7 downto 4) <= temp;
					count <= count + 1;
				else
					COUNT_OUT <= COUNT_OUT + 1;
				end if;
			elsif (en = '0' and en1 = '1' and en2 = '0') then
					temp <= temp(2 downto 0) & name2(conv_integer(count));
					LED(5 downto 2) <= temp;
					count <= count + 1;
				else
				end if;
			elsif (en = '0' and en1 = '0' and en2 = '1') then
					temp <= temp(2 downto 0) & name3(conv_integer(count));
					LED(3 downto 0) <= temp;
					count <= count + 1;
				else
				end if;
			elsif (en = '0' and en1 = '0' and en2 = '0') then
					count <= (others => '0');
					LED <= (others => '0');
					temp <= (others => '0');
			end if;
		end if;
	end process;
end Behavioral;
Tags (3)
jheslip
looking at the DCM wizard it is setup correctly, are you saying instead of 50 and 25 you are getting 50 and 12.5 Mhz?
Are you looking at the output clocks on a scope or just looking at the LEDs?
dimas_mmf
I am just looking at the LEDs.
How can I make it so that you can not enter an additional signal (tsl_amunt)?
jheslip
can you try and scope the signals, as the DCM setup looks correct.
Also, i don't see TSL_amunt in your code above can you explain further?
