Observer abhishek7
data sheet for spi flash winbond on spartan6
Hi am using spi interface on spartan6 sp605,it contains winbond spi flash (Winbond W25Q64VSFIG) am unable to find datasheet for particular part number  am getting all other data sheets except this particular part number can you please help me out?
regards
abhishek
Scholar pratham
Re: data sheet for spi flash winbond on spartan6
@abhishek7 https://www.pjrc.com/store/w25q64fv.pdf
-Pratham
Please find  required Winbond data sheet in the below link
http://www.winbond.com/resource-files/w25q64fv%20revr%2010262016.pdf
Observer abhishek7
Hi@pratham thanks for your reply but the the data sheet which you mentioned in the link is  with part number W25Q64FV flash,but on spartan6(sp605) the SPI flash is with W25Q64VSFIG part number.I cannot find any data sheet for this particular part number is both the part numbers same????
regards
Abhishek
Observer abhishek7
Hi@umamahe thanks for your reply but the the data sheet which you mentioned in the link is  with part number W25Q64FV flash,but on spartan6(sp605) the SPI flash is with W25Q64VSFIG part number.I cannot find any data sheet for this particular part number is both the part numbers same????
regards
Abhishek
