Newbie krtkeyan
need to change the delay for trafiic code in xc3s250e 144 Options
------------ TRAFFIC LIGHT CONTROLLER--------------------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity TrafficLight is
    Port ( Port_A : inout  STD_LOGIC_VECTOR (7 downto 0);
           Port_B : inout  STD_LOGIC_VECTOR (7 downto 0);
           Port_C : inout  STD_LOGIC_VECTOR (7 downto 0);
           clk : in  STD_LOGIC);
end TrafficLight;
architecture Behavioral of TrafficLight is
type main1 is array(1 to 13) of std_logic_vector(7 downto 0);
signal state1:main1:=(x"0f",x"4d",x"8b",x"49",x"01",x"00"
,x"89",x"02",x"00",x"30"
,x"c0",x"f0",x"30");
signal sig : std_logic_vector(29 downto 0) := "000000000000000000000000000000";
signal cnt:integer:=1;
begin
process
begin
wait until clk'event and clk='1';
    sig<=sig+1;
    case sig(25 downto 20) is
    when "000000" =>
              if cnt = 1 then
                    cnt <= cnt+1;
                Port_B <= state1(1);
                     Port_A <= state1(2);
                     sig(25 downto 20)<="000111";
                 elsif cnt = 2 then
                    cnt <= cnt+1;
                     sig(25 downto 20)<="000110";
                 elsif cnt = 3 then
                    cnt <= cnt+1;
                     Port_A <= state1(3);
             elsif cnt = 4 then
                    cnt <= cnt+1;
                 elsif cnt = 5 then
                    cnt <= cnt+1;
                     Port_A <= state1(4);
                     Port_C <= state1(5);
                 elsif cnt <= 6 then
                    cnt <= cnt+1;
                     Port_C <= state1(6);
                 elsif cnt <= 7 then
                    cnt <= cnt+1;
                     Port_A <= state1(7);
                     Port_C <= state1(8);
                 elsif cnt <= 8 then
                    cnt <= cnt+1;
                     Port_C <= state1(9);
                     Port_A <= state1(10);
                     sig(25 downto 20)<="010000";
                 elsif cnt <= 9 then
                    cnt <= cnt+1;
                     Port_A <= state1(11);
                     Port_B <= state1(12);
                elsif cnt <= 10 then
                    cnt <= cnt+1;
                     Port_A <= state1(13);
                else
                    cnt <= 1;
                 end if;
    when "000110" =>                -- For Amber delay;
             Port_A <= "00111001";        --0x39;
              sig(25 downto 20)<="001000";
    when "110000" =>
              sig(25 downto 20)<="000000";     -- For Delay;
when others => null;
end case;
end process;
end architecture;
already there are the comments to change the values but i don't know what value should i give so, please give the sugessions to increase or decrease the delay of this traffic light code.,i'm having  xc3s250e pq144
Professor
Professor
Re: need to change the delay for trafiic code in xc3s250e 144 Options
I don't see the comments that you are talking about.  And what delay do you mean?
I can see that there is a long counter and you're only using the upper bits in a case
statement.  Are you talking about the time to go from one state to the next in this
case statement?  Or were you talking about adding additional states?
-- Gabor
Historian
Historian
You fail.
What you coded is not how one should implement a state machine's state register and decoder.
Professor
Professor
@bassman59 wrote:
You fail.
Strangely I thought I had already seen this code before.  I looked around and found this:
http://forums.xilinx.com/t5/CPLDs/need-to-convert-the-code-for-xc95144TQ100-FROM-xc3s250e/m-p/300385
-- Gabor
Historian
Historian
@gszakacs wrote:
@bassman59 wrote:
You fail.
Well, I've informed his professor that he should be failed for not actually doing the work. ;)
