Visitor cutitcom
needing suggestion to build an pci ethernet card
hi all, i am working on a PCI Ethernet card  (NIC).
1. Do you have any example or document to build this ?
2. which relevant kit should i buy to do this with a low cost for this only purpose?
thanks for help
Scholar kotir
Re: needing suggestion to build an pci ethernet card
What is the device targetted ?
Is this conventional  PCI or PCI Express based product you are looking for ?
E\What is the Ethernet spec 1G of further ?
You can refer to all 5, 6 series xilinx eval kits have PCIe and Ethernet RJ45 interfaces.
V5- ML555,ML505/6/7
S6 - SP605
V6-ML605
There are 7 series cards with SFP cages capable for using 10G applications also.
A7 - AC701
K7-KC705
V7-VC707/9
KR
Historian
Historian
thanks for help
Pretty much all Ethernet controller chips have PCI or PCIe interfaces, so why are you asking about this on an FPGA design forum?
Visitor cutitcom
thanks for helps.
firlstly, i am looking for PCIe standard.
Secondly, i need a kit with example code  relevant to my issuse as much as possible. it will be the best if there is a NIC example. easy to develop is the most important.
Last but not least, the price of board .
Could you suggest me some? thanks
Visitor cutitcom
speed 1GB . please give me a reference design or example for both ethernet and pcie together
Historian
Historian
You're not getting it. Why do you need an FPGA?
Scholar kotir
Can you please elaborate about end goas as bassman is asking ?
There are some asics which already has this functionality in market.
Even though we do not have understanding about complete details of your end goal, i am assuming that you are trying to build your own NIC in FPGA.
For this you need to have a pcie core and ethernet cores. the Xilinx IP catalog has these cores. You can use them.
 There is no readymade solution for you.
For 7 series, there are Targetted referance designs which has both networking and PCIe cores are used to build a NIC like design. You can refer to them for guidance.
I hope this helps.
KR
