huangjielg
strange idcode loop error with IMPACT
  I have a strange problem:
   1) without programing  fpga ,  impact id code loop without any error for 10000 tims;
   2) after programing fpga, impact id code looop will have random error
   3) after I burn out all chip except fpga itself, just the same as before.
   4) I use xc3s250epq208
  some one can help me ?
Anonymous
Not applicable
Check the power supply load capabilities. Check the voltages after programming the FPGA. The voltages should be as per data sheet recommendations.
bassman59
Historian
Historian
Zombies are BACK!
