donengelbert
strataflash memory
Hello.
I have a problem in using the intel strataflash memory. Please share some information on how to program in vhdl  the stratalash memory.
I am designing a code so I can test the strataflash memory but its seems I have a problem when I run the Implement Design in ISE.
Please give me some example code plainly in vhdl and directly to strataflash memory.
Thank you.
dannyel
donengelbert, I hope you can finally resolve this problem, I'm trying to interface with StrataFlash with Nexys2 programming in Verilog and I can't hold the values I write when I power off the FPGA, so I'm looking for some code (Driver) but I found nothing yet, if you have something to share, I'll appreciate it! thanks.
Dannyel.
xainalvi
same issue did u guys manage to solve this problem ? I made a code and all but nothing is working for me.
https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/Nexys2-writing-flash-issue-Help/m-p/681339
