using ISE webPACK on Spartan 6 XC6SLX150
I have a Spartan 6 XC6SLX150.  I need to use PlanAhead and Microblaze to get my custom software ready.  I do not need all the memory and space of the XC6SLX150.  Can I run the ISE webPACK on the XC6SLX150 and get access to only half the chip (same size as XC6SLX75)?
https://www.xilinx.com/publications/matrix/Software_matrix.pdf
Re: using ISE webPACK on Spartan 6 XC6SLX150
as already mentioned this cannot be done the webpack license is fixed and so you cannot adjust based on the utilization you want.
You will either need to get a full ISE license or access to a device supported by WebPack
no way :) . you can only use webpack supported devices with webpack license
Thanks and Regards
Balkrishan
thank you for information
