Visitor tvgod2000
I want to know the delay between I and O in any BUFFER.
Hi, I'm using Spartan6 SP605 evaluation board.
I refer to "ds162_DC and Switching Characters datasheet" but only found the BUFGMUX delay from I to O.
If I want to know the delay from I to O in another buffer(OBUF, IBUF), what should I refer to? Or can you let me know?
And the additional question, is it possible to function as a buffer that only BUFG, OBUF, IBUF?
If there is anything else, please reply. Thank you.
Scholar watari
Re: I want to know the delay between I and O in any BUFFER.
Hi @tvgod2000
Would you do STA with what you want to use ?
It depends on IO buffer type (ex. LVTTL, LVDS and SSTL-18...).
Visitor tvgod2000
Thanks your advice!!
I have additional question for your reply.
I don't know what the STA is. Can you tell me? and What I need is a delay(time) from I to O of OBUF and IBUF. If there is a difference between STA and not, can you tell me that too?
If it is LVCMOS25, is a typical delay value? What does mA mean behind it?
Scholar watari
Hi @tvgod2000
"STA" is abbreviation of  "Static Timing Analysis".
Also you need netlist (NGD file), some timing constraints (UCF file) and timing report file (PAR file).
Would you refer the followings ?
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_timing_analysis_overview.htm
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pp_p_process_analyze_post_place_route_static_timing.htm
> Will you be able to use CMOS as the input buffer other than BUFG, IBUF, and OBUF in LVCMOS25 and push-pull as the output buffer?
What do you mean "CMOS" ? If you mean CMOS as "LVCMOS3.3", you should define IO type in UCF file.
If you want to know more detail, would you refer the following document ?
https://www.xilinx.com/support/documentation/user_guides/ug381.pdf
Visitor tvgod2000
I just corrected my reply. Can you answer the second question?
If i 'm using IBUF in LVCMOS25, it is okay to assume that the typical value of delay is 0.82ns?
and Are there any elements that only function as BUFFER that connect wires? (except for IBUF, OBUF and BUFG)
Thank you for your reply. I'll use the reference material you gave me. Thank you!
Scholar watari
Hi @tvgod2000
What you mentioned is right without output buffer.
In this case (output buffer), you need to consider an extra path delay by load value.
> Are there any elements that only function as BUFFER that connect wires ?
What do you mean ?
Do you want to know cell delay ?
If yes, it's almost right.
Because, some device has different cell delay between rising and falling.
can you explain why you need this very specific detail, normally customers would just run an STA on the whole design that would take care of these buffer delays, I would select the correct BUFFER for what you need not based on the delay trough it.
