Impact 923 cable error
I have change my PC from 32bit to 64bit, my OS is new WIN 7.
Now I have allways a Impact 923 Error : can not find cable, check cable setup
Installed ISE  is 11.5 as 32 bit application, it run ok.
But I can not run my Platform Cable USB II (DLC10). Impact4 release Version 11.5 on my new PC.
I have try to install driver  as  a 64 bit application as described in ug344:
c:\ Xilinx11_5\Impact\nt64 with : wdreg - inf uninstall.inf -silent -log uninstall.log uninstall
c:\ Xilinx11_5\Impact\nt64 with : wdreg - inf xusbdrvr.inf -log install_xusb.log uninstall
The both files uninstall.inf and xusbdrvr.inf are in the directory  but in the uninstall.log is warning :
--- ....uninstall.inf  not found..
I trying in Impact  the Autoconnect, Cable Setup, cable Reset etc, is without success.
I have try any solution as AR#30184 or AR#54381  and other without success.
The platform cable run ok on the 32bit PC with Win XP.
What can I do to install the Platform Cable on my new 64bit PC ?
Thank You in advance
Anton
Scholar pratham
Re: Impact 923 cable error
@antonkurka Glad to know! Please close this thread
-Pratham
Scholar pratham
@antonkurka First up all Windows 7 OS is not supported with ISE 11.X. Either you install latest version of ISE i.e 14.7 or go back to XP.
I would prefer to go with windowws 7 and ISE 14.7, this combo should work. Let us know if this doesnt work. You can download 14.7 from here
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v2012_4---14_7.html
-Pratham
Hallo Pratham
Thank You for prompt answer.
The ISE 11.5 run very well in compatibility mode XP unter Win7, only IMPACT  does not work
My design is very large and this is the reason why I have not update to higher  version because the limitation of WebPack.
What limit does the free version  of14.7  ?
My design has 35 entities and any (10)coregen units and targeted Spartan6: xc6lx100-3fgg484, is this possible with free Version of ISE 14.7 ?
Anton
Scholar pratham
@antonkurka Yes, No Problem
-Pratham
Hallo Pretham
I have Download ISE 14.7 and will beginning with the installation.
Which version 14.7  I can install free  ?
Anton
Scholar pratham
@antonkurka Webpack can be used. If you just want to configure you may consider using labtools which is free and doesnt need any license.
-Pratham
Hallo Pratham
I need only the xc6lx100-3fgg484, no other devices.
Is there is no way a free license only for for this device?
I have seen in :
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/irn.pdf
are supported devices for Webpack only: XC6SLX4 - XC6SLX75T .
Anton
Scholar pratham
@antonkurka No this device isnt listed in webpack support. You have to purchase a license if using this device otherwise consider using 75t
-Pratham
Hallo Pratham
I have installed the Labtools and the IMPACT programm on the 64bit machine work very well.
Thank you very match for Your excellent support.
Best regards
Anton
Scholar pratham
-Pratham
Accept as solution
I try to give You Kudos but it dont function
Newbie alj1108
Dear Moderator,
Figure this one out then...First of all I do have ver14.7 loaded and also have a 64Bit Win7 enterprise as the OS .. the cable is not being seen in the program but is being seen in the device manger as Jungo 10.2.1.0 and  Xlinx  2.0.0.3.. Tried everything under the sun and on the website to get this to work (uninstalling and reinstalling everything)....
Need.... help
Newbie jwen2882
Please help! I am facing the same issue when I try to initialize a JTAG chain using Platform Cable II.
Please advise what I should do.
Jing Wen
