Visitor bloct1
resloved: failed to program xc3s400an internal flash,Done not gone go high!
Hello.
I'm using XC3S400AN and am trying to program to internal flash.
Then pins are set as follows:
Mode pin:  M2=0, M1=1, M0=1
VS0,1,2= : 1,1,1
Prog_B,pudc_b,init,din,dclk:  pulled high with external resistors
Done:  pulled high with external resistors by 330R (1.5K)
Suspend:  grounded
the fpga can runing by jtag but canot promgramming to internal flash
After programing 60% then stop on there
in console shows:
programming successful
verify successful
Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and spi mode settings
I've trid a lot, but I could not find what is wrong in my case.
Then, could you give me some  advises, please ? thank you very much.
replaced the xc3s400an_spi.cor then sloved the problem.
Scholar drjohnsmith
Re: failed to program xc3s400an internal flash,Done not gone go high!
what program you using to program with ?
   what OS ?
Visitor bloct1
ISE 14.7   win7 64   jtag
