Visitor wangjiayu
Abnormal program termination (11)
I have a question when i synthesis a project ,vivado 2016.4 crashed.
INFO: [Synth 8-638] synthesizing module 'DW_axi_busmux__parameterized105' [/home/jywang/fpga_a7/src/verilog/axi/DW_axi.lst.v:97559]
 Parameter BUS_COUNT bound to: 5 - type: integer
 Parameter MUX_WIDTH bound to: 75 - type: integer
 Parameter SEL_WIDTH bound to: 3 - type: integer
Please check '/home/jywang/fpga_a7/top/top/top.runs/synth_1/hs_err_pid7806.log' for details
Parent process (pid 7806) has died. This helper process will now exit
Re: Abnormal program termination (11)
Hi @wangjiayu,
Which OS are you using?
Can you try setting module 'DW_axi_busmux__parameterized105' as top if possible and run synthesis again to see if crash is possible? Do you have a test case that you can share in community?
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Hi @wangjiayu,
Have you tried to synthesize the design using different strategies ?
If so, Are you facing the same Abnormal Termination(11) while using different strategies ?
Is this a random crash ?
Thanks & Regards,
A. Shameer.
Crash happens during elaboration stage itself while binding parameter.
Will it be possible to share your project file?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Newbie thodoe
Hi Guys,
I have the problem Abnormal program termination (11) in synthesis step with vivado 2017.2 when i have
the pcie core included in design.
The design was already running with PCIe but now it doesn't work. The design without PCIE works fine but not together.
Stack:
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fb959d3a4b0]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenDelayArc::computeDelayAndSlew(TNInstC*, TGenC const*, BRFTime&, RF<TTimeShort>&, bool, RF<TTimeShort>, bool, bool) const+0x289) [0x7fb91f579e99]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenDelayArc::delay(TNInstC*, bool, TGenC const*, bool, bool) const+0x1b7) [0x7fb91f57a4d7]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenDelay::writeTimingArc(_IO_FILE*, UStrBuf, UStrBuf, TNGenC*, TNInstC const*) const+0x14b) [0x7fb91f57287b]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenPinBase<TGenDelaysArray>::writeTimingArc(_IO_FILE*, UStrBuf, int, TNGenC*, TNInstC const*) const+0x1b1) [0x7fb91f575c81]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenC::writeTimingArc(TNInstC const*, char*) const+0x1a0) [0x7fb91f5747c0]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNInstC::tCreate()+0x1ee) [0x7fb91f59b5be]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNInstC::cacheDelay(int, int, int, BRFTime&, bool)+0x114) [0x7fb91f59e1e4]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenDelayArc::computeDelayAndSlew(TNInstC*, TGenC const*, BRFTime&, RF<TTimeShort>&, bool, RF<TTimeShort>, bool, bool) const+0x1e8) [0x7fb91f579df8]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TGenPin::updateDrvArcs(TNInstC*, bool, TGenC*, bool)+0x886) [0x7fb91f57c806]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNInstC::updateDrvArcs(int, bool, bool)+0xf9) [0x7fb91f59fe49]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNPinC::updateDrvArcs(bool, bool)+0x55) [0x7fb91f5b1425]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNPinC::updateDriverAndLoadingPins(int, TNetInfo&, bool)+0x17a) [0x7fb91f5b180a]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNPinC::updateDriverAndNetArcs(bool)+0x133) [0x7fb91f5bb993]
/opt/Xilinx/Vivado/2017.2/lib/lnx64.o/librdi_synth.so(TNPinC::slew(TBiIn)+0x21e) [0x7fb91f5bc8de]
Who can help me to fix that.
Christoph
Hi @thodoe
Can you share the vivado.log file?
Did you get a chance to synthesize this design in latest vivado 2017.4?
If you can provide testcase that will help me to further investigate this issue.
Newbie thodoe
Hi yes please find attached the file,
yes we have tried to check this with 2017.4 but it is the same result. The point is, that this
issue occurs since last RTL design changes ... that means it has to work and there must be an issue in
combination with the PCIe
Thank your very much for short response :-)
 Thomas
Hi @thodoe
Can you share the project with me?
If you can share project, I will send you ezmove link where you can upload files.
Visitor pankaj11
Hi There,
I too face the same issue across vivado versions. I am using 2018.2 right now. My design was working fine till day before yesterday. But after changing one file in my design I started seeing this again. It fails everytime at the same stage. The file changed does not have any big changes, lint is clean as well on that file.
Please help.
Finished Applying XDC Timing Constraints : Time (s): cpu = 00:48:45 ; elapsed = 00:50:52 . Memory (MB): peak = 12220.281 ; gain = 10420.875 ; free physical = 45953 ; free virtual = 880713
Start Timing Optimization
Please check 'synth/hs_err_pid14864.log' for details
Pipestatus: 139
I have attached the log file.
Hi @pankaj11 ,
Please create a new thread with your query because this is an old thread. In this way, community will help you better to resolve your query.
hemangd
Hi @pankaj11
Is it possible for you to share testcase?
Manusha
Visitor pankaj11
Visitor pankaj11
Hi Manusha,
Its proprietery design...so I won't be able to share it. Sorry  !!
