02-09-2020 09:35 PM - edited 02-09-2020 09:48 PM
I'm writing a simple D-flip-flop in Verilog and looking at what it synthesizes to. Here's what I have:
module d_flip_flop( input d, input clr, input clk, input ce, output reg q ); always @(posedge clk) begin: d_flip_flop if (clr) begin q <= 1'b0; end else if (ce) begin
q <= d; end end endmodule
And it synthesizes to:
However, making this change to the code and adding CE to the sensitivity list:
module d_flip_flop( input d, input clr, input clk, input ce, output reg q ); always @(posedge clk or posedge ce) begin: d_flip_flop if (clr) begin q <= 1'b0; end else if (ce) begin q <= d; end end endmodule
It synthesizes to:
What is going on? Why would adding CE to the sensitivity list make this synthesize to a buffer?
Thanks!
02-12-2020 09:31 AM
This is one of those cases where Vivado should be giving a synthesis error. Instead it synthesizes without issue, even though it can't implement the desired logic.
"Why would adding CE to the sensitivity list make this synthesize to a buffer?"
means that clr is synchronous to both clk and ce, which can't be done on an FPGA. Your first code example is the correct way to code a flip-flop with synchronous reset and enable.
02-12-2020 09:31 AM
02-12-2020 09:53 AM
Hi @vivadouser67 ,
I agree with @steven_bellock Vivado should have issued error. This can't be modelled in flop.
Btw, did you intend to put clr in senstitvity list
always@(posedge clk or posedge clr)
begin
if(clr)
end
Ajay
02-13-2020 12:16 AM
First, adding CE in the sensitivity list is not a common way to describe an FF. This may be the reason why Vivado Synthesis gives the only-buffer result.
Second, please check the Synthesis log and see if it gives any message about this always statement. I would expect some messages in the log about this.
-vivian
02-13-2020 06:42 PM
Your explanation makes perfect sense! It's sad to see the synthesis tool be so useless in this situation though. I'd say this is a bug.
The only warning I see is: "[Synth 8-3331] design d_flip_flop has unconnected port ce" which is pointless.
Thank you!
