shaikon
Voyager
Voyager
BOARD_PIN vs PACAKGE_PIN
Some of the auto-generated XDC files in my design use the BOARD_PIN location while others use PACAKGE_PIN.
My question:
What's the motivation behind using BOARD_PIN instead of PACAKGE_PIN ?
austin
I understand what a package pin is.  It is the physical point on the package that gets soldered to the pcb.
I do not understand what a board pin is.  Is this the view from the board looking back to the package (?).
I see people using both terms, but while the first means something (to me), the second does not have a defined meaning that I am aware of.
Austin Lesea
Principal Engineer
Xilinx San Jose
florentw
Hi @shaikon,
BOARD_PIN is used when the tool knows the board you are using. It knows to which PACKAGE_PIN it needs to connect the BOARD_PIN.
By default  would use PACKAGE_PIN to avoid being dependent on a specific board
Florent
shaikon
Voyager
Voyager
So why ever bother with BOARD_PIN ?
Why was it invented ??
florentw
Hi @shaikon,
Because it could be simple in some case.
When you use IPI with a board, you can use the board pins to do design automatically. So in this case, vivado will use BOARD_PIN.
But if you have to manually write constraint, I would recommend to use PACKAGE_PIN
Florent
