06-08-2020 02:51 PM
Hello!
I have a problem with Vivado 2019.2 synthesis (behavioral simulation works as expected). I have a module instance array, where the ports are connected to arrays of their respective types, expecting each module instance to pick up the corresponding array element. This used to work fine, but recently I modified the type of one of the ports, which became a struct containing another struct. Simulation continued to work, but I get an error during synthesis.
Minimal example (System Verilog):
typedef struct {
logic c;
} B;
typedef struct {
B b;
//logic b;
} A;
module Mymodule(
input A a
endmodule
module Top(
A a;
Mymodule mymodule (
.a(a)
A aa[0:9];
Mymodule mymodules[0:9] (
.a(aa)
endmodule
synth_design gives me:
ERROR: [Synth 8-448] named port connection 'a[b[c]]' does not exist for instance 'mymodules' of module 'Mymodule' [xxx.sv:26]
Connecting a single (non-array) instance is fine. Replacing the "B b" definition with "logic b" to eliminate the struct-in-struct also works. Please confirm if this is a bug. Cheers.
06-08-2020 09:51 PM
Hi @GP
Yes, this is a bug in Vivado synthesis with array of module instance with nested struct port.
Will report this to get fixed in future release.
-Shreyas
06-08-2020 09:51 PM
Hi @GP
-Shreyas
06-09-2020 02:16 PM
Thanks. It seems that a "generate for" can be a straightforward workaround for this, but a fix would be even better.
