Visitor nleclerc
BUG - Streaming concatenation in non-assignment context
  I found what I believe to be a bug in synthesis.  Using systemverilog streaming operator to reverse a vector.
The following constuct leads to an error: ([Synth 8-27] streaming concatenation in non-assignment context not supported)
assign d_w = REFLECT_INPUT?d:{<<{d}};
But if you break it in two:
assign dRev_w = {<<{d}};
assign d_w = REFLECT_INPUT?d:dRev_w;
works like a charm.
Teacher muzaffer
Re: BUG - Streaming concatenation in non-assignment context
IEEE Std 1800 says: "It shall be an error to use a streaming_concatenation as an operand in an expression without first casting it to a bit-stream type" so I think Vivado is doing the right thing complaining here.
Teacher muzaffer
