[BUG VIVIVADO 2019.2] Invalid operator for type of expression
I have the following simple VHDL 2008 code.
library ieee;
use ieee.std_logic_1164.all;
entity str_test is
port (
  op    : out std_logic
end entity;
architecture rtl of str_test is
  constant EN : boolean := true;
begin
  op <= '1' when to_string(EN) = "true" else '0';
end architecture;
 No bugs are highlighted in the code window, but when trying to synthesise or open the elaborated design, you get the following eroneous error:
[Synth 8-5883] invalid operator type for expression ["D:/playarea/str_test.vhd":14]
It is a perfectly valid operator. In addition, there should be no problem with the string compare as it evaluates to a constant.
Re: [BUG VIVIVADO 2019.2] Invalid operator for type of expression
This is extra silly, because the compiler clearly can clearly see the "to_string" function, as otherwise it would complain about it not being declared (like you get when you switch to VHDL 93).
Even more fun, this code works fine:
library ieee;
entity str_test is
port (
  op    : out std_logic
end entity;
  constant EN : boolean := false;
  function to_string(b : boolean) return string is
  begin
    if b then return "true";
    else      return "false";
    end if;
  end function;
begin
end architecture;
@richardhead  "when trying to synthesise or open the elaborated design, you get the following eroneous error"
I've griped to Xilinx previously about their poor VHDL-2008 support for to_string(), but to no avail.
Although my gripe was in the context of wanting synthesis assertions using  to_string(real,format) to enable the troubleshooting of synthesis bugs within elaboration time computations using reals (e.g. sin lookup tables, filter coefficients, etc.).
-Brian
@brimdavis
I also find it strange given that vivado finally has most VHDL 2008 features supported that are useful for synthesis, namely generic packages, generic types and functions as generics. But yet they still cannot support to_string(). It just feels odd that a custom to_string function works just fine!
Can someone confirm they have raised a Defect Report for this?
Hi @richardhead
Reported this issue.
Manusha
