joel.sanchez
Binding instances
I don't really know what happens to my synthesis design, but now, it is binding instances with mesages like:
WARNING: [Synth 8-115] binding instance 'xxxx' in module 'yyyy' to reference 'zzzz' which has no pins
I use generate loops but all values are correct and I didn't change anything of the code, is there any option to disable binding instances? What could have happened?
joel.sanchez
Hi @anusheel,
I have been working on the code and today I solved the issue. If someone has a similar issue, in my case was, because one of the inputs of the generated instantiations was wrong.
Joel
anusheel
@joel.sanchez
Can you please show us the generate block here and details of the tool used to synthesize the design?
Anusheel
joel.sanchez
Hi @anusheel,
I have been doing the synthesis of all my modules that work with generate loop, and only the project top module have this error.
I'm doing the synthesis with Vivado 2017.4.1 for Virtex UltraScale+ with the default values of synthesis.
 The generate loop it's the next:
genvar i;
generate for(i= 0; i< `VALUE; i++)
begin : gen_loop
mod1
mod1_inst
//signals with output/input
end
endgenerate
`VALUE is a define created which value is 8: `define VALUE 8
I don't understand why this doesn't work well.
Thanks for helping.
Joel
anusheel
@joel.sanchez
The code structure looks correct, can you please share a test case?
Anusheel
joel.sanchez
Hi @anusheel,
Joel
