Bits Missing in Netlist after Synthesis
Using Vivado 2015.3. I created an extremely simple design which includes a 32-bit counter:
          reg [31:0] count;
After synthesis the 1st item under Nets in the Netlist is
         count_reg(25)
The 1st 7 bits are not enumerated. The synthesis log contains
      Detailed RTL Component Info :
      +---Registers :
                         16 Bit    Registers := 2
so it recognizes my other 2 shorter registers. What happened to 'count'? I also tried shortening it to just fit the max count I'm allowing, but it still "ignores" the 1st 7 bits of that length. Further down in the Netlist the 1st 7 bits are enumerated as
       count_reg_n_0[0]
       count_reg_n_0[6]
Any clues?
HI,
Can you please share the testcase?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Hi @space_boy,
Can you please attach the synthesis log here?
-Rajesh
Hi @space_boy,
It depends upon your assignments and usage of the count signals. Make sure you have valid connections for these signals. VSS must be throwing few warnings for these signals before removing. Give DONT_TOUCH property to these signals and check connection after synthesis and observe whether the connectivity is valid or not.
We need to look into the RTL code to comment on this behaviour.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
SOLVED: Thanks for the input and interest in the problem. I found the setting "keep equivalent registers" which, when set, keeps the bits of the register contiguous. Without it, some of the bits were presumably "optimized" into a different arrangement.
Ron
Hi @space_boy,
Please mark the answer as accepted solution to close this thread.
-Shreyas
