ly4096
Bug report: Vivado2017.1 and 2017.2: Access violation error and fault synthesis of foreach statement
parameter NUM_SENSORS=5;
bit[NUM_SENSORS-1:0] sensors;
typedef struct {
bit invalid;
bit[22:0] sweepOffset=0;
} PerSensorData;
typedef struct {
//bit[1:0] lspStatus;
bit[3:0] syncCode[2];
int unsigned cycleLength;
PerSensorData sensorData[NUM_SENSORS];
} LspData;
LspData result;
bit clearResult=0; always @(posedge clk) begin foreach (sensors[i]) begin if (clearResult) begin result.sensorData[i].sweepOffset<=0; result.sensorData[i].invalid<=1; end end end
The code above generated the following error during synthesis:
ERROR: [Synth 8-280] expression must be constant: assignment pattern index value
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
The error message did not point out the position in code, so I found the code above manually by commenting out always blocks.
If I comment out everything related to
the problem will go away. Looks like the synthesizer is unable to resolve index of an array.
The code above can pass all procedures in 2016.4 version with no problem.
anusheel
@ly4096
Can you please share the full test case for us to reproduce the issue?
Anusheel
Helpful answer -> Give Kudos
pulim
Hi @ly4096
I am able to reproduce the issue at my end.Will be filing a CR on this.
pulim
Hi @ly4096
Filed CR#980258 for this issue.
ly4096
Thanks!
I've been out for a few days but glad to see this issue being reproduced.
