Case range: Syntax error near "[". Vivado 2019.1
That code gives Syntax error near "[".
        case(subcnt)
          0:begin
            states <= AA;
          end
          [1:4]:begin
            states <= CC;
          end
        endcase
https://www.xilinx.com/support/answers/64777.html
Re: Case range: Syntax error near "[". Vivado 2019.1
Hi @alexis_jp ,
I suspect you are missing inside keyword after the case(subcnt), without inside keyword Vivado shows an error on the line you mentioned.
Try adding inside keyword after the case statement and check if it helps.
Ansari Hunen
Hi @alexis_jp ,
Ansari Hunen
