[Common 17-69] Command failed: Unable to run synthesis. No HDL sources found in project
I have a project that gives OOC synthesis errors when I try to build it. It worked fine for weeks. The missing source files are related to an AXI interconnect. I've tried reseting the IP.
Are there any other ideas?
Winefred
Try "Generate Output Product" in the right click menu for this IP.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
-vivian
