awoz92gmu
Congestion Reports: Is "Router Maximum" more concerning than "Placed Maximum" ?
I'm new to interpreting congestion reports and I'm trying to build some intuition.
After generating a Congestion Report in Vivado from the "Design Analysis" tool under the Reports tab, I'm curious of how to best analyze the results.
It seems that the results under "Placed Maximum" sometimes are more or less resolved by the time they are routed, or at least aren't as bad in the "Router Maximum" report. Is high congestion more concerning before or after routing?
I'd like to know which report is better for pinpointing problems/areas of concern regarding congestion, the "Placed Maximum" or "Router Maximum" reports.  Also what are some things that can be done to alleviate congestion?
drjohnsmith
post routing, the too,s have tried to make the design fit and meet speed, and have probably done a lot of replication / push back / forward of registers, and optimisation,
if you have congestion before P&R , then its going to take the tools more struggle to try to un congest.
You need to re think your code is the answer.
If you think of the inside as a conveyor belt made of buckets, then if the buckets all feed one other bucket, and get input from one bucket, then you can wrap that into a wiggle to fit inside the square fpga.
Bu if some buckets need input from more than one bucket, and some feed multiple buckets, you have more of a mesh, much harder to fold into the square shape.
Aim for your algorithms to be the same,
if you have to get a signal from one part of the chip to another, it needs to be placed close by by the tools. If you put a bunch or delay registers in this path, the tools have much more time to get the signals across the chip.
The other thing we see, is people with a C background, coding up RTL without any thought of what the logic is ,
an example, I ahve been working with some code that did not fit,
they had bunches of mutlipliers ,mutliplying by 7 and others by 15 in a quiet complex configuration.
A quick translation of the algorithm into a tree lattic, and replacement of the * 7 multipliers by multiply by 8 and subtract 1 , and the 15 by * 16 and subtract 1 , meant they did not have to use as many multipliers, and they have more pipe line, it fits in less area, and runs faster.
Good luck
BTW:
If you above about 75 % utilisation, your pain will increase.
drjohnsmith
Good luck
BTW:
awoz92gmu
@drjohnsmith Thanks for the answer and useful insights.
