msau
Difference between AXI interconnect and AXI smartconnect
first I'm new with the AXI Interface. What is the difference between the AXI Interconnect und AXI Smartconnect IP core? Which need I if I want to connect the DDR4-MIG to the AXI interface of the Zynq.
Thank you for your help.
br
martin sauer
florentw
Hi @msau,
Both IP have the same functionnalities.
AXI SmartConnect is the successor to AXI Interconnect, it uses a different IP technology. You should use it for any new design.
Hope that helps,
Kind Regards,
Florent
Florent
florentw
Hi @msau,
Hope that helps,
Kind Regards,
Florent
Florent
simchask
I created a design with a MIG and microblaze. The automatic routing and block automation created both and interconnect and a smartconnect. Are they both needed or is Vivado simply inefficient in this case?
florentw
Hi @simchask,
I guess it depends in some case. I might be that some IPs are still expecting the AXI interconnect.
If you have further query, please create a new topic
Florent
samcossais
I wouldn't say go blindly for AXI SmartConnect because last time I checked (about 10 months ago) SmartConnect was much bigger than AXI Interconnect and because our FPGA was very short on ressources, we went back to AXI Interconnect.
But right now I am working on a different projetct and this time I need a very fast version and I don't care much about ressources. So how about the frequency performance ?
samcossais
I just read the release notes of Vivado 2019.1 and it mentions that the SmartConnect IP has been improved:
https://www.xilinx.com/products/design-tools/vivado.html#new
"SmartConnect: Improved area efficiency, especially for small configurations and AXILite endpoints"
It makes sense to me as it's exactly what I had experienced. I had a small FPGA using quite a lot of i2c IPs connected to my Zynq CPU through AXI lite interfaces and AXI Interconnect IP. When I tried to change from AXI Interconnect to SmartConnect the ressources used increased a lot (I don't remember exactly how much but it was pretty huge). On the other hand I did the same replacement in a system connecting several PCIe x8 IPs and an HBM interface, and SmartConnect wasn't really bigger and it gave much better timing results.
So with the latest version I guess there is a good chance that SmartConnect is better optimized than the AXI Interconnect.
pedro_uno
Advisor
Advisor
There is still another reason for using AXI Interconnect instead of Smart Connect. AXI Interconnect can give you an AXI Lite interface while it looks like Smart Connect only provides full AXI-4 interfacing.  This is a problem if you have written cores, say a register file, that usis AXI Lite.  It is much easier to work with AXI Lite than the full interface, something like 19 signals versus about thirty.
DSP in hardware and software
samcossais
SmartConnect can give you AXI Lite interfaces too. It auto configures to fit any type of AXI interface actually. The only thing as I mention in my last comment (if you read it...) is that the AXI Lite interfaces used to take more ressources in SmartConnect compared to AXI Interconnect. And that's what they changed recently if you look at the SmartConnect version history. I haven't checked yet but I wouldn't be surprised if it now takes the same ressources as the AXI Interconnect, making the latter obsolete, SmartConnect having better performance and same area.
Turkey9999999
One difference I notice is that the AXI interconnect makes you connect a clock and reset for every port, verses smartconnect that only takes a single clock and reset, and then I suppose it must automatically connect the clocks?  Not sure, didn't seem to work for AXI PCIE core that sources a clock...
joancab
You can select in SmartConnect to have individual clocks if needed. A single (common) clock is the default, that is handy.
Turkey9999999
I was just noticing that...The Smartconnect is significantly easier to connect compared to AXI INTERCONNECT for multiple clock domains...
Turkey9999999
Seems like you don't need to synchronize the reset either with the Smartconnect and can just pull the reset directly from the output of the ZYNQ...  Is that true as well?  AXI_INTERCONNECT always complains about synchronizing the reset to the clock...
