Digital Clock ( Nexys4 DDR Artix-7 FPGA Board)
I want to make a Digital Clock on FPGA but the segment variable in seven_four.vhd is always "1111111". How the 'sec' variable can be different than '00','01','10' and '11'.
@kaanibis,
1. Show us the complete code; where is counter defined?
2. Use signals, don't use variables.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
