Observer teqdruid
Disable Cross Boundary Optimization
Hi Everyone-
I just upgraded from Vivado 2013.4 to 2014.2 and compilation time went from 45 minutes to over six hours! In Vivado 2014.2, a synthesis optimization "Cross Boundary Optimization" takes about 6 hours. Is there any way to disable this optimization? I don't see it specifically referenced anywhere under project settings.
~John
Re: Disable Cross Boundary Optimization
In synthesis settings change the "flatten hierarchy" to NONE and see if that helps.
Deepika.
Deepika.
Try using the directive RuntimeOptimized for synthesis
Thanks,Vijay
Observer teqdruid
When I disable hierarchy flattening, the PCIe core I'm using doesn't meet timing.
I've ended up using the RuntimeOptimization directive. Which, by the way, is the dumbest possible name for what it is. Is it optimizing the runtime of my hardware or the tools? and "directive"? That doesn't help. Effort_level made sense. This one took me a non-trivial amount of time with google to figure out.
Anyway, I was hoping to disable only that optimization. Is there no flag for that? If not, just the lower effort appears to do the trick.
~John
I have seen an issue in 2014.2.
Can you try running the below command in the TCL console before launching synthesis run?
set_param synth.elaboration.rodinMoreOptions "set rt::extractNetlistGenomes false
Lets know if this helps.
Achutha
Visitor bangzhao
I am also stuck in "Start Cross Boundary Optimization";
And your way can not work.
Do you have other solutions? Thank you!
