Newbie ma8d9
ERROR:HDLCompilers:28
Hi;
I wrote a code but when I synthesize it app take this error
ERROR:HDLCompilers:28 - "sp3v2.v" line 58 'state' has not been declared
I think this error is for the word "state" but I check it and the word is correct.
I put the code here
module uart_comm (
// Hashing Clock Domain
input hash_clk,
input rx_new_nonce,
input [31:0] rx_golden_nonce,
output reg tx_new_work = 1'b0,
output reg [255:0] tx_midstate = 256'd0,
output reg [95:0] tx_data = 96'd0,
// UART Clock Domain
input comm_clk,
input rx_serial,
output tx_serial
localparam MSG_BUF_LEN = 60;
// States
localparam STATE_IDLE = 4'b0001;
localparam STATE_READ = 4'b0010;
localparam STATE_PARSE = 4'b0100;
localparam STATE_SEND = 4'b1000;
// Message Types
localparam MSG_INFO = 0;
localparam MSG_INVALID = 1;
localparam MSG_RESEND = 3;
// Configuration data
reg [351:0] current_job = 352'd0;
reg [255:0] midstate = 256'd0;
reg new_work_flag = 1'b0;
reg [95:0] data = 96'd0;
// UART Modules
wire uart_rx_flag, uart_tx_busy;
wire [7:0] uart_rx_byte;
reg uart_tx_we;
reg [7:0] uart_tx_data;
uart_rx uart_rx_blk (
.clk (comm_clk),
.rx_serial (rx_serial),
.tx_flag (uart_rx_flag),
.tx_byte (uart_rx_byte)
uart_tx_fifo uart_tx_blk (
.clk (comm_clk),
.rx_we (uart_tx_we),
.rx_data (uart_tx_data),
.tx_busy (uart_tx_busy),
.tx_serial (tx_serial)
// CRC32 Module
wire crc_reset = (state == STATE_IDLE);
wire crc_we = uart_rx_flag & (state == STATE_IDLE || state == STATE_READ);
wire [7:0] crc_data = uart_rx_byte;
wire [31:0] crc;
CRC32 crc_blk (
.clk (comm_clk),
.reset (crc_reset),
.rx_we (crc_we),
.rx_byte (crc_data),
.tx_crc (crc)
reg [63:0] system_info = 256'hDEADBEEF13370D13;
// RX Message Buffer
reg [63:0] outgoing_msg;
reg [7:0] outgoing_msg_type;
reg [MSG_BUF_LEN*8-1:0] msg_data;
reg [7:0] msg_length, length, msg_type;
reg [3:0] state = STATE_IDLE;
always @ (posedge comm_clk)
begin
uart_tx_we <= 1'b0;
case (state)
//// Waiting for new packet
STATE_IDLE: if (uart_rx_flag) begin
if (uart_rx_byte == 0) // PING
begin
uart_tx_we <= 1'b1;
uart_tx_data <= 8'd1; // PONG
end
else if (uart_rx_byte < 8) // Invalid Length
begin
length <= 8'd1;
msg_length <= 8'h8;
msg_type <= MSG_INVALID;
state <= STATE_SEND;
end
else
begin
length <= 8'd2;
msg_length <= uart_rx_byte;
state <= STATE_READ;
end
end
//// Reading packet
STATE_READ: if (uart_rx_flag) begin
msg_data <= {uart_rx_byte, msg_data[MSG_BUF_LEN*8-1:8]};
length <= length + 8'd1;
if (length == 8'd4)
msg_type <= uart_rx_byte;
if (length == msg_length)
state <= STATE_PARSE;
end
//// Parse packet
STATE_PARSE: begin
// By default, we'll send some kind of
// response. Special cases are handled below.
length <= 8'd1;
msg_length <= 8'd8;
if (crc != 32'd0)
msg_type <= MSG_RESEND;
else if (msg_type == MSG_INFO && msg_length == 8)
begin
msg_type <= MSG_INFO;
msg_data <= system_info;
msg_length <= 8'd16;
end
else
end
//// Send packet
STATE_SEND: begin
uart_tx_we <= 1'b1;
if (length == 8'd1)
uart_tx_data <= msg_length;
else if (length == 8'd2 || length == 8'd3)
uart_tx_data <= 8'h00;
else if (length == 8'd4)
uart_tx_data <= msg_type;
else if (length <= msg_length)
begin
uart_tx_data <= msg_data[7:0];
msg_data <= {8'd0, msg_data[MSG_BUF_LEN*8-1:8]};
end
state <= STATE_IDLE;
end
endcase
end
endmodule
thanks in advance
Voyager
Voyager
Re: ERROR:HDLCompilers:28
Aside from single-bit-wide wires (which can be inferred), you cannot use a variable before you declare it.
Assuming the problem line 58 is :
you don't declare reg [3:0] state until ~20 lines later.
Move the usage line after the declaration line, or move the declaration ahead of the usage.
-Joe G.
Voyager
Voyager
-Joe G.
Newbie ma8d9
-Joe G.
Thanx man
