Participant sachinb_apt1
ERROR: [Synth 8-439] module 'XPM_FIFO_ASYNC' not found for Webpack 2017.4
I have just one file in the project which is basically a wrapper to FIFO in which i infer XPM_FIFO_ASYNC a
Xilinx Parameterized macro.
I synthesis using the below command
synth_design -top my_afifo -part xcku5p-sfvb784-2-e -verilog_define XILINX
and i get the above error.
I expected the macro should be detected by Vivado. But not if the issue is because i am using Webpack.
Can some one from XLNX explain?
Sachin B
Re: ERROR: [Synth 8-439] module 'XPM_FIFO_ASYNC' not found for Webpack 2017.4
Are you perhaps using the non-project flow (no GUI)? In the GUI, it should automatically recognize the XPM macros, however if you are using a script, you need to issue the "auto_detect_xpm" command after you read in your source files.
Please don’t forget to reply, kudo, and accept as solution!
Follow the steps:
1) Open Block design
2) Right Click on Custom IP block {Indicated in error message}
3) Click on Edit in IP packager
4)Go to IP files group --> Is Include ( Unchecked this column)
5)Go to Review and Package --> Re-package IP
6) Then Validate the complete block design and Re-run the synthesis.
Thanks and Regards
Balkrishan
You can try the following:
create_project -in_memory
set_property XPM_LIBRARIES XPM_FIFO [current_project]
