ERROR:Xst:528 - Multi-source in Unit <TOPLEVEL> on signal <XLXN_3725>; this signal is connected to multiple drivers.
I'm modifying a schematic designed by someone else in ISE 11.1 webpack. I had this error when synthesizing. The signal in the error is simply tied between VCC and the input of a submodule. That's it. There's no driver at all. The same circuit was succesfully compiled in another project. I'm confused.
Can you attach your project? Then we can reproduce the problem and try to help you.
-Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
please check the answer record# 14264 < http://www.xilinx.com/support/answers/14264.htm >, this may help you.
Thanks for the offer. But I can't attach the project since it's proprietary.
I used Edit-Find to search the net name. There's only one wire found. The signal is used to enable a sub-circuit. It's a constant '1' and is not driven by anything.
Thanks. I still don't find where my error came from. The signal is a wire between Vcc and the Enable input of a sub-circuit. It's not driven by anything.
You are synthesizing HDL code right?
When you say that you connected VCC to the enable pin, did you really mean that you assigned a logic 1 to the port like this.
Verilog   .enable(1'b1)
VHDL       enable => '1'
or did you do this some other way?
Have you examined the sub-module and confirmed that the enable pin is not assigned anywhere in the sub-module?
I'm synthesizing a schematic designed by someone else. VCC is connected to the Enable input of the submodule directly. It's not assigned anywhere else.
Synthesizing a schematic???  How, and maybe why, are you doing that?
