multiprobe
Elaboration/Synthesis drops ports from block design
I am using  Vivado 2014.4, I seem to have an issue with one of my block designs.
I have a few output ports in my block design, which get ignored after elaboration step.
I also get warnings : "[Common 17-55] 'set_property' expects at least one object. ["C:/Users/sowmya/Desktop/backups/PS_Top_21May/PS_Top.srcs/constrs_1/new/PS_plus_fabric_wrapper.xdc":33]"
For each of the constraint line where i try to set an IOSTANDARD or a PACKAGE_PIN property yo these ports.
Why are the ports being dropped? I tried deleting and recrating these ports, no change.
Attaching screenshots of relevant constraints,block design, and the warnings
pratham
@multiprobe go to tcl console and run
Get_ports
This tcl command returns all the ports,
You should be able to see these ports. If output of this tcl command does not include led_right,left and so then these ports are not there and you should check for synthesis warnings,this may give a clue what is happening with these ports
-Pratham
syedz
You can also use the following command in "open synthesized design"
show_objects -name find_1 [get_ports -filter { NAME =~ "*" } ]
This command will list all the IO ports of your design where you can set the properly set the IOSTANDARD and Site using the drop down menu as shown below. When you save the design then the changes will get reflected in XDC file.
If you do not see the LED ports with above command then as suggested by Pratham check synthesis the log file or warnings on these ports.
--Syed
