Error Xst:1535 index line is not in the range of array
Hi there,
Surprisingly, there is another similar thread on the Old ISE Board, that was read 3,000 times but no answer nor other appearances of the Xst:1535 error.
Well i've just got it: ERROR:Xst:1535 - "<file_name>.v" line 628: Index value is not in Range of array.
 I'll be more specific and attach all relevant code ( error msg points to the line marked with @@@@@@):
     parameter NUM_OF_CHANS = 14;
     wire [NUM_OF_CHANS-1:0] PSelChan;
     generate
     for (k=0 ; k<MAX_NUM_OF_CHANS ; k=k+1)
        begin : channel
        assign PSelChan[k] = PSel && (PAddr[15:6] == {6'h 1,k[3:0]});                              // @@@@@@@@@
     channel channel (
i tried to change the PSelChan array to:
     wire  PSelChan [MAX_NUM_OF_CHANS-1:0];
but then i got an error HDLCompilers:149 Illegal operand of unary operator '|'error on the following statement:
     assign PSelChans = |PSelChan;
Any Ideas?
Tags (5)
Re: Error Xst:1535 index line is not in the range of array
Yo Ho ! You realy nailed it.
After several trials, and discovering that this genvar k doesn't like to help anyone (i.e. cannot assign a wire to it) i replaced the rebellious line and it worked:
     assign PSelChan[k] = PSel && (PAddr[15:10] == 6'h 1) && (PAddr[9:6] == k);
Thanks a lot.
Professor
Professor
The index I think it's referring to is k[3:0]
I don't see a declaration of k
Perhaps this should be declared as a genvar?
-- Gabor
Ouch, forgot to mention that I have this declaration, however as global (in the module where all other parameters, regs and wires are declared) and not inside the generate block. I tried to put it inside genertae block but same result (i.e. same error).
i will try to mitigate the k[3:0]. maybe indeed it's there....
genvar          k;
Thanks a lot.
