Observer dck140130
Failed Synthesis, and Elaboration for recursive function call in Vivado 2017.4
What you will find attached is atypical in many ways. There is no explicit timing other than an always sensitivity list in the top module that calls a function that calls many other functions, a couple of which are recursive. I want this to be an asynchronous pipeline of functions.
You will find the automatic keyword on the recursive functions.
I have not attempted to recode using generate blocks as is found here (http://jad-reads.blogspot.com/2009/03/recursive-and-iterative-designs-in.html)
I have tried using the following command found in the Vivado User guide:  " -recursion_iteration_limit 2" ,
pg 222 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug901-vivado-synthesis.pdf
The errors are only that synthesis fails. Synthesis attempt uses 16 gb of ram. Please feel free to use one of the non recursive functions found in the header file to realize that elaboration is possible and synthesis still fails due to lack of IO constraints.
 The header file "fibhead.vh" is not attached because forum will not allow me attach if not in .v. I have changed the file to .v and it is still not letting me attach.I have replied twice to this post with all of the functions that belong in the header file.
Observer dck140130
Re: Failed Synthesis, and Elaboration for recursive function call in Vivado 2017.4
function [1:0] cmp_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: cmp_0_lut = 2'b01;
6'b011111: cmp_0_lut = 2'b10;
6'b101111: cmp_0_lut = 2'b10;
6'b110111: cmp_0_lut = 2'b11;
6'b010111: cmp_0_lut = 2'b01;
6'b100111: cmp_0_lut = 2'b10;
6'b111011: cmp_0_lut = 2'b11;
6'b011011: cmp_0_lut = 2'b11;
6'b101011: cmp_0_lut = 2'b01;
6'b111101: cmp_0_lut = 2'b01;
6'b011101: cmp_0_lut = 2'b10;
6'b101101: cmp_0_lut = 2'b10;
6'b110101: cmp_0_lut = 2'b11;
6'b010101: cmp_0_lut = 2'b01;
6'b100101: cmp_0_lut = 2'b10;
6'b111001: cmp_0_lut = 2'b11;
6'b011001: cmp_0_lut = 2'b11;
6'b101001: cmp_0_lut = 2'b01;
6'b111110: cmp_0_lut = 2'b01;
6'b011110: cmp_0_lut = 2'b10;
6'b101110: cmp_0_lut = 2'b10;
6'b110110: cmp_0_lut = 2'b11;
6'b010110: cmp_0_lut = 2'b01;
6'b100110: cmp_0_lut = 2'b10;
6'b111010: cmp_0_lut = 2'b11;
6'b011010: cmp_0_lut = 2'b11;
6'b101010: cmp_0_lut = 2'b01;
default: cmp_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isLess_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isLess_0_lut = 2'b10;
6'b011111: isLess_0_lut = 2'b11;
6'b101111: isLess_0_lut = 2'b11;
6'b110111: isLess_0_lut = 2'b10;
6'b010111: isLess_0_lut = 2'b11;
6'b100111: isLess_0_lut = 2'b11;
6'b111011: isLess_0_lut = 2'b10;
6'b011011: isLess_0_lut = 2'b11;
6'b101011: isLess_0_lut = 2'b11;
6'b111101: isLess_0_lut = 2'b10;
6'b011101: isLess_0_lut = 2'b11;
6'b101101: isLess_0_lut = 2'b11;
6'b110101: isLess_0_lut = 2'b10;
6'b010101: isLess_0_lut = 2'b11;
6'b100101: isLess_0_lut = 2'b11;
6'b111001: isLess_0_lut = 2'b10;
6'b011001: isLess_0_lut = 2'b11;
6'b101001: isLess_0_lut = 2'b11;
6'b111110: isLess_0_lut = 2'b10;
6'b011110: isLess_0_lut = 2'b11;
6'b101110: isLess_0_lut = 2'b11;
6'b110110: isLess_0_lut = 2'b10;
6'b010110: isLess_0_lut = 2'b11;
6'b100110: isLess_0_lut = 2'b11;
6'b111010: isLess_0_lut = 2'b10;
6'b011010: isLess_0_lut = 2'b11;
6'b101010: isLess_0_lut = 2'b11;
default: isLess_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isGreater_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isGreater_0_lut = 2'b11;
6'b011111: isGreater_0_lut = 2'b11;
6'b101111: isGreater_0_lut = 2'b10;
6'b110111: isGreater_0_lut = 2'b11;
6'b010111: isGreater_0_lut = 2'b11;
6'b100111: isGreater_0_lut = 2'b10;
6'b111011: isGreater_0_lut = 2'b11;
6'b011011: isGreater_0_lut = 2'b11;
6'b101011: isGreater_0_lut = 2'b10;
6'b111101: isGreater_0_lut = 2'b11;
6'b011101: isGreater_0_lut = 2'b11;
6'b101101: isGreater_0_lut = 2'b10;
6'b110101: isGreater_0_lut = 2'b11;
6'b010101: isGreater_0_lut = 2'b11;
6'b100101: isGreater_0_lut = 2'b10;
6'b111001: isGreater_0_lut = 2'b11;
6'b011001: isGreater_0_lut = 2'b11;
6'b101001: isGreater_0_lut = 2'b10;
6'b111110: isGreater_0_lut = 2'b11;
6'b011110: isGreater_0_lut = 2'b11;
6'b101110: isGreater_0_lut = 2'b10;
6'b110110: isGreater_0_lut = 2'b11;
6'b010110: isGreater_0_lut = 2'b11;
6'b100110: isGreater_0_lut = 2'b10;
6'b111010: isGreater_0_lut = 2'b11;
6'b011010: isGreater_0_lut = 2'b11;
6'b101010: isGreater_0_lut = 2'b10;
default: isGreater_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isEqual_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isEqual_0_lut = 2'b11;
6'b011111: isEqual_0_lut = 2'b10;
6'b101111: isEqual_0_lut = 2'b11;
6'b110111: isEqual_0_lut = 2'b11;
6'b010111: isEqual_0_lut = 2'b10;
6'b100111: isEqual_0_lut = 2'b11;
6'b111011: isEqual_0_lut = 2'b11;
6'b011011: isEqual_0_lut = 2'b10;
6'b101011: isEqual_0_lut = 2'b11;
6'b111101: isEqual_0_lut = 2'b11;
6'b011101: isEqual_0_lut = 2'b10;
6'b101101: isEqual_0_lut = 2'b11;
6'b110101: isEqual_0_lut = 2'b11;
6'b010101: isEqual_0_lut = 2'b10;
6'b100101: isEqual_0_lut = 2'b11;
6'b111001: isEqual_0_lut = 2'b11;
6'b011001: isEqual_0_lut = 2'b10;
6'b101001: isEqual_0_lut = 2'b11;
6'b111110: isEqual_0_lut = 2'b11;
6'b011110: isEqual_0_lut = 2'b10;
6'b101110: isEqual_0_lut = 2'b11;
6'b110110: isEqual_0_lut = 2'b11;
6'b010110: isEqual_0_lut = 2'b10;
6'b100110: isEqual_0_lut = 2'b11;
6'b111010: isEqual_0_lut = 2'b11;
6'b011010: isEqual_0_lut = 2'b10;
6'b101010: isEqual_0_lut = 2'b11;
default: isEqual_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] notLess_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: notLess_0_lut = 2'b11;
6'b011111: notLess_0_lut = 2'b10;
6'b101111: notLess_0_lut = 2'b10;
6'b110111: notLess_0_lut = 2'b11;
6'b010111: notLess_0_lut = 2'b10;
6'b100111: notLess_0_lut = 2'b10;
6'b111011: notLess_0_lut = 2'b11;
6'b011011: notLess_0_lut = 2'b10;
6'b101011: notLess_0_lut = 2'b10;
6'b111101: notLess_0_lut = 2'b11;
6'b011101: notLess_0_lut = 2'b10;
6'b101101: notLess_0_lut = 2'b10;
6'b110101: notLess_0_lut = 2'b11;
6'b010101: notLess_0_lut = 2'b10;
6'b100101: notLess_0_lut = 2'b10;
6'b111001: notLess_0_lut = 2'b11;
6'b011001: notLess_0_lut = 2'b10;
6'b101001: notLess_0_lut = 2'b10;
6'b111110: notLess_0_lut = 2'b11;
6'b011110: notLess_0_lut = 2'b10;
6'b101110: notLess_0_lut = 2'b10;
6'b110110: notLess_0_lut = 2'b11;
6'b010110: notLess_0_lut = 2'b10;
6'b100110: notLess_0_lut = 2'b10;
6'b111010: notLess_0_lut = 2'b11;
6'b011010: notLess_0_lut = 2'b10;
6'b101010: notLess_0_lut = 2'b10;
default: notLess_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] notGreater_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: notGreater_0_lut = 2'b10;
6'b011111: notGreater_0_lut = 2'b10;
6'b101111: notGreater_0_lut = 2'b11;
6'b110111: notGreater_0_lut = 2'b10;
6'b010111: notGreater_0_lut = 2'b10;
6'b100111: notGreater_0_lut = 2'b11;
6'b111011: notGreater_0_lut = 2'b10;
6'b011011: notGreater_0_lut = 2'b10;
6'b101011: notGreater_0_lut = 2'b11;
6'b111101: notGreater_0_lut = 2'b10;
6'b011101: notGreater_0_lut = 2'b10;
6'b101101: notGreater_0_lut = 2'b11;
6'b110101: notGreater_0_lut = 2'b10;
6'b010101: notGreater_0_lut = 2'b10;
6'b100101: notGreater_0_lut = 2'b11;
6'b111001: notGreater_0_lut = 2'b10;
6'b011001: notGreater_0_lut = 2'b10;
6'b101001: notGreater_0_lut = 2'b11;
6'b111110: notGreater_0_lut = 2'b10;
6'b011110: notGreater_0_lut = 2'b10;
6'b101110: notGreater_0_lut = 2'b11;
6'b110110: notGreater_0_lut = 2'b10;
6'b010110: notGreater_0_lut = 2'b10;
6'b100110: notGreater_0_lut = 2'b11;
6'b111010: notGreater_0_lut = 2'b10;
6'b011010: notGreater_0_lut = 2'b10;
6'b101010: notGreater_0_lut = 2'b11;
default: notGreater_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] notEqual_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: notEqual_0_lut = 2'b10;
6'b011111: notEqual_0_lut = 2'b11;
6'b101111: notEqual_0_lut = 2'b10;
6'b110111: notEqual_0_lut = 2'b10;
6'b010111: notEqual_0_lut = 2'b11;
6'b100111: notEqual_0_lut = 2'b10;
6'b111011: notEqual_0_lut = 2'b10;
6'b011011: notEqual_0_lut = 2'b11;
6'b101011: notEqual_0_lut = 2'b10;
6'b111101: notEqual_0_lut = 2'b10;
6'b011101: notEqual_0_lut = 2'b11;
6'b101101: notEqual_0_lut = 2'b10;
6'b110101: notEqual_0_lut = 2'b10;
6'b010101: notEqual_0_lut = 2'b11;
6'b100101: notEqual_0_lut = 2'b10;
6'b111001: notEqual_0_lut = 2'b10;
6'b011001: notEqual_0_lut = 2'b11;
6'b101001: notEqual_0_lut = 2'b10;
6'b111110: notEqual_0_lut = 2'b10;
6'b011110: notEqual_0_lut = 2'b11;
6'b101110: notEqual_0_lut = 2'b10;
6'b110110: notEqual_0_lut = 2'b10;
6'b010110: notEqual_0_lut = 2'b11;
6'b100110: notEqual_0_lut = 2'b10;
6'b111010: notEqual_0_lut = 2'b10;
6'b011010: notEqual_0_lut = 2'b11;
6'b101010: notEqual_0_lut = 2'b10;
default: notEqual_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] equal_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: equal_0_lut = 2'b10;
6'b011111: equal_0_lut = 2'b11;
6'b101111: equal_0_lut = 2'b11;
6'b110111: equal_0_lut = 2'b11;
6'b010111: equal_0_lut = 2'b10;
6'b100111: equal_0_lut = 2'b11;
6'b111011: equal_0_lut = 2'b11;
6'b011011: equal_0_lut = 2'b11;
6'b101011: equal_0_lut = 2'b10;
6'b111101: equal_0_lut = 2'b10;
6'b011101: equal_0_lut = 2'b11;
6'b101101: equal_0_lut = 2'b11;
6'b110101: equal_0_lut = 2'b11;
6'b010101: equal_0_lut = 2'b10;
6'b100101: equal_0_lut = 2'b11;
6'b111001: equal_0_lut = 2'b11;
6'b011001: equal_0_lut = 2'b11;
6'b101001: equal_0_lut = 2'b10;
6'b111110: equal_0_lut = 2'b10;
6'b011110: equal_0_lut = 2'b11;
6'b101110: equal_0_lut = 2'b11;
6'b110110: equal_0_lut = 2'b11;
6'b010110: equal_0_lut = 2'b10;
6'b100110: equal_0_lut = 2'b11;
6'b111010: equal_0_lut = 2'b11;
6'b011010: equal_0_lut = 2'b11;
6'b101010: equal_0_lut = 2'b10;
default: equal_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isMin_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isMin_0_lut = 2'b10;
6'b011111: isMin_0_lut = 2'b11;
6'b101111: isMin_0_lut = 2'b11;
6'b110111: isMin_0_lut = 2'b10;
6'b010111: isMin_0_lut = 2'b11;
6'b100111: isMin_0_lut = 2'b11;
6'b111011: isMin_0_lut = 2'b10;
6'b011011: isMin_0_lut = 2'b11;
6'b101011: isMin_0_lut = 2'b11;
6'b111101: isMin_0_lut = 2'b10;
6'b011101: isMin_0_lut = 2'b11;
6'b101101: isMin_0_lut = 2'b11;
6'b110101: isMin_0_lut = 2'b10;
6'b010101: isMin_0_lut = 2'b11;
6'b100101: isMin_0_lut = 2'b11;
6'b111001: isMin_0_lut = 2'b10;
6'b011001: isMin_0_lut = 2'b11;
6'b101001: isMin_0_lut = 2'b11;
6'b111110: isMin_0_lut = 2'b10;
6'b011110: isMin_0_lut = 2'b11;
6'b101110: isMin_0_lut = 2'b11;
6'b110110: isMin_0_lut = 2'b10;
6'b010110: isMin_0_lut = 2'b11;
6'b100110: isMin_0_lut = 2'b11;
6'b111010: isMin_0_lut = 2'b10;
6'b011010: isMin_0_lut = 2'b11;
6'b101010: isMin_0_lut = 2'b11;
default: isMin_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isNegative_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isNegative_0_lut = 2'b10;
6'b011111: isNegative_0_lut = 2'b11;
6'b101111: isNegative_0_lut = 2'b11;
6'b110111: isNegative_0_lut = 2'b10;
6'b010111: isNegative_0_lut = 2'b11;
6'b100111: isNegative_0_lut = 2'b11;
6'b111011: isNegative_0_lut = 2'b10;
6'b011011: isNegative_0_lut = 2'b11;
6'b101011: isNegative_0_lut = 2'b11;
6'b111101: isNegative_0_lut = 2'b10;
6'b011101: isNegative_0_lut = 2'b11;
6'b101101: isNegative_0_lut = 2'b11;
6'b110101: isNegative_0_lut = 2'b10;
6'b010101: isNegative_0_lut = 2'b11;
6'b100101: isNegative_0_lut = 2'b11;
6'b111001: isNegative_0_lut = 2'b10;
6'b011001: isNegative_0_lut = 2'b11;
6'b101001: isNegative_0_lut = 2'b11;
6'b111110: isNegative_0_lut = 2'b10;
6'b011110: isNegative_0_lut = 2'b11;
6'b101110: isNegative_0_lut = 2'b11;
6'b110110: isNegative_0_lut = 2'b10;
6'b010110: isNegative_0_lut = 2'b11;
6'b100110: isNegative_0_lut = 2'b11;
6'b111010: isNegative_0_lut = 2'b10;
6'b011010: isNegative_0_lut = 2'b11;
6'b101010: isNegative_0_lut = 2'b11;
default: isNegative_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isOne_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isOne_0_lut = 2'b11;
6'b011111: isOne_0_lut = 2'b11;
6'b101111: isOne_0_lut = 2'b10;
6'b110111: isOne_0_lut = 2'b11;
6'b010111: isOne_0_lut = 2'b11;
6'b100111: isOne_0_lut = 2'b10;
6'b111011: isOne_0_lut = 2'b11;
6'b011011: isOne_0_lut = 2'b11;
6'b101011: isOne_0_lut = 2'b10;
6'b111101: isOne_0_lut = 2'b11;
6'b011101: isOne_0_lut = 2'b11;
6'b101101: isOne_0_lut = 2'b10;
6'b110101: isOne_0_lut = 2'b11;
6'b010101: isOne_0_lut = 2'b11;
6'b100101: isOne_0_lut = 2'b10;
6'b111001: isOne_0_lut = 2'b11;
6'b011001: isOne_0_lut = 2'b11;
6'b101001: isOne_0_lut = 2'b10;
6'b111110: isOne_0_lut = 2'b11;
6'b011110: isOne_0_lut = 2'b11;
6'b101110: isOne_0_lut = 2'b10;
6'b110110: isOne_0_lut = 2'b11;
6'b010110: isOne_0_lut = 2'b11;
6'b100110: isOne_0_lut = 2'b10;
6'b111010: isOne_0_lut = 2'b11;
6'b011010: isOne_0_lut = 2'b11;
6'b101010: isOne_0_lut = 2'b10;
default: isOne_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isPositive_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isPositive_0_lut = 2'b11;
6'b011111: isPositive_0_lut = 2'b11;
6'b101111: isPositive_0_lut = 2'b10;
6'b110111: isPositive_0_lut = 2'b11;
6'b010111: isPositive_0_lut = 2'b11;
6'b100111: isPositive_0_lut = 2'b10;
6'b111011: isPositive_0_lut = 2'b11;
6'b011011: isPositive_0_lut = 2'b11;
6'b101011: isPositive_0_lut = 2'b10;
6'b111101: isPositive_0_lut = 2'b11;
6'b011101: isPositive_0_lut = 2'b11;
6'b101101: isPositive_0_lut = 2'b10;
6'b110101: isPositive_0_lut = 2'b11;
6'b010101: isPositive_0_lut = 2'b11;
6'b100101: isPositive_0_lut = 2'b10;
6'b111001: isPositive_0_lut = 2'b11;
6'b011001: isPositive_0_lut = 2'b11;
6'b101001: isPositive_0_lut = 2'b10;
6'b111110: isPositive_0_lut = 2'b11;
6'b011110: isPositive_0_lut = 2'b11;
6'b101110: isPositive_0_lut = 2'b10;
6'b110110: isPositive_0_lut = 2'b11;
6'b010110: isPositive_0_lut = 2'b11;
6'b100110: isPositive_0_lut = 2'b10;
6'b111010: isPositive_0_lut = 2'b11;
6'b011010: isPositive_0_lut = 2'b11;
6'b101010: isPositive_0_lut = 2'b10;
default: isPositive_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] isZero_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: isZero_0_lut = 2'b11;
6'b011111: isZero_0_lut = 2'b10;
6'b101111: isZero_0_lut = 2'b11;
6'b110111: isZero_0_lut = 2'b11;
6'b010111: isZero_0_lut = 2'b10;
6'b100111: isZero_0_lut = 2'b11;
6'b111011: isZero_0_lut = 2'b11;
6'b011011: isZero_0_lut = 2'b10;
6'b101011: isZero_0_lut = 2'b11;
6'b111101: isZero_0_lut = 2'b11;
6'b011101: isZero_0_lut = 2'b10;
6'b101101: isZero_0_lut = 2'b11;
6'b110101: isZero_0_lut = 2'b11;
6'b010101: isZero_0_lut = 2'b10;
6'b100101: isZero_0_lut = 2'b11;
6'b111001: isZero_0_lut = 2'b11;
6'b011001: isZero_0_lut = 2'b10;
6'b101001: isZero_0_lut = 2'b11;
6'b111110: isZero_0_lut = 2'b11;
6'b011110: isZero_0_lut = 2'b10;
6'b101110: isZero_0_lut = 2'b11;
6'b110110: isZero_0_lut = 2'b11;
6'b010110: isZero_0_lut = 2'b10;
6'b100110: isZero_0_lut = 2'b11;
6'b111010: isZero_0_lut = 2'b11;
6'b011010: isZero_0_lut = 2'b10;
6'b101010: isZero_0_lut = 2'b11;
default: isZero_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] notNegative_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: notNegative_0_lut = 2'b11;
6'b011111: notNegative_0_lut = 2'b10;
6'b101111: notNegative_0_lut = 2'b10;
6'b110111: notNegative_0_lut = 2'b11;
6'b010111: notNegative_0_lut = 2'b10;
6'b100111: notNegative_0_lut = 2'b10;
6'b111011: notNegative_0_lut = 2'b11;
6'b011011: notNegative_0_lut = 2'b10;
6'b101011: notNegative_0_lut = 2'b10;
6'b111101: notNegative_0_lut = 2'b11;
6'b011101: notNegative_0_lut = 2'b10;
6'b101101: notNegative_0_lut = 2'b10;
6'b110101: notNegative_0_lut = 2'b11;
6'b010101: notNegative_0_lut = 2'b10;
6'b100101: notNegative_0_lut = 2'b10;
6'b111001: notNegative_0_lut = 2'b11;
6'b011001: notNegative_0_lut = 2'b10;
6'b101001: notNegative_0_lut = 2'b10;
6'b111110: notNegative_0_lut = 2'b11;
6'b011110: notNegative_0_lut = 2'b10;
6'b101110: notNegative_0_lut = 2'b10;
6'b110110: notNegative_0_lut = 2'b11;
6'b010110: notNegative_0_lut = 2'b10;
6'b100110: notNegative_0_lut = 2'b10;
6'b111010: notNegative_0_lut = 2'b11;
6'b011010: notNegative_0_lut = 2'b10;
6'b101010: notNegative_0_lut = 2'b10;
default: notNegative_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] notPositive_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: notPositive_0_lut = 2'b10;
6'b011111: notPositive_0_lut = 2'b10;
6'b101111: notPositive_0_lut = 2'b11;
6'b110111: notPositive_0_lut = 2'b10;
6'b010111: notPositive_0_lut = 2'b10;
6'b100111: notPositive_0_lut = 2'b11;
6'b111011: notPositive_0_lut = 2'b10;
6'b011011: notPositive_0_lut = 2'b10;
6'b101011: notPositive_0_lut = 2'b11;
6'b111101: notPositive_0_lut = 2'b10;
6'b011101: notPositive_0_lut = 2'b10;
6'b101101: notPositive_0_lut = 2'b11;
6'b110101: notPositive_0_lut = 2'b10;
6'b010101: notPositive_0_lut = 2'b10;
6'b100101: notPositive_0_lut = 2'b11;
6'b111001: notPositive_0_lut = 2'b10;
6'b011001: notPositive_0_lut = 2'b10;
6'b101001: notPositive_0_lut = 2'b11;
6'b111110: notPositive_0_lut = 2'b10;
6'b011110: notPositive_0_lut = 2'b10;
6'b101110: notPositive_0_lut = 2'b11;
6'b110110: notPositive_0_lut = 2'b10;
6'b010110: notPositive_0_lut = 2'b10;
6'b100110: notPositive_0_lut = 2'b11;
6'b111010: notPositive_0_lut = 2'b10;
6'b011010: notPositive_0_lut = 2'b10;
6'b101010: notPositive_0_lut = 2'b11;
default: notPositive_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] notZero_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: notZero_0_lut = 2'b10;
6'b011111: notZero_0_lut = 2'b11;
6'b101111: notZero_0_lut = 2'b10;
6'b110111: notZero_0_lut = 2'b10;
6'b010111: notZero_0_lut = 2'b11;
6'b100111: notZero_0_lut = 2'b10;
6'b111011: notZero_0_lut = 2'b10;
6'b011011: notZero_0_lut = 2'b11;
6'b101011: notZero_0_lut = 2'b10;
6'b111101: notZero_0_lut = 2'b10;
6'b011101: notZero_0_lut = 2'b11;
6'b101101: notZero_0_lut = 2'b10;
6'b110101: notZero_0_lut = 2'b10;
6'b010101: notZero_0_lut = 2'b11;
6'b100101: notZero_0_lut = 2'b10;
6'b111001: notZero_0_lut = 2'b10;
6'b011001: notZero_0_lut = 2'b11;
6'b101001: notZero_0_lut = 2'b10;
6'b111110: notZero_0_lut = 2'b10;
6'b011110: notZero_0_lut = 2'b11;
6'b101110: notZero_0_lut = 2'b10;
6'b110110: notZero_0_lut = 2'b10;
6'b010110: notZero_0_lut = 2'b11;
6'b100110: notZero_0_lut = 2'b10;
6'b111010: notZero_0_lut = 2'b10;
6'b011010: notZero_0_lut = 2'b11;
6'b101010: notZero_0_lut = 2'b10;
default: notZero_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] fullAdd_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: fullAdd_0_lut = 2'b01;
6'b011111: fullAdd_0_lut = 2'b10;
6'b101111: fullAdd_0_lut = 2'b11;
6'b110111: fullAdd_0_lut = 2'b10;
6'b010111: fullAdd_0_lut = 2'b11;
6'b100111: fullAdd_0_lut = 2'b01;
6'b111011: fullAdd_0_lut = 2'b11;
6'b011011: fullAdd_0_lut = 2'b01;
6'b101011: fullAdd_0_lut = 2'b10;
6'b111101: fullAdd_0_lut = 2'b10;
6'b011101: fullAdd_0_lut = 2'b11;
6'b101101: fullAdd_0_lut = 2'b01;
6'b110101: fullAdd_0_lut = 2'b11;
6'b010101: fullAdd_0_lut = 2'b01;
6'b100101: fullAdd_0_lut = 2'b10;
6'b111001: fullAdd_0_lut = 2'b01;
6'b011001: fullAdd_0_lut = 2'b10;
6'b101001: fullAdd_0_lut = 2'b11;
6'b111110: fullAdd_0_lut = 2'b11;
6'b011110: fullAdd_0_lut = 2'b01;
6'b101110: fullAdd_0_lut = 2'b10;
6'b110110: fullAdd_0_lut = 2'b01;
6'b010110: fullAdd_0_lut = 2'b10;
6'b100110: fullAdd_0_lut = 2'b11;
6'b111010: fullAdd_0_lut = 2'b10;
6'b011010: fullAdd_0_lut = 2'b11;
6'b101010: fullAdd_0_lut = 2'b01;
default: fullAdd_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] fullAdd_1_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: fullAdd_1_lut = 2'b11;
6'b011111: fullAdd_1_lut = 2'b11;
6'b101111: fullAdd_1_lut = 2'b01;
6'b110111: fullAdd_1_lut = 2'b11;
6'b010111: fullAdd_1_lut = 2'b01;
6'b100111: fullAdd_1_lut = 2'b01;
6'b111011: fullAdd_1_lut = 2'b01;
6'b011011: fullAdd_1_lut = 2'b01;
6'b101011: fullAdd_1_lut = 2'b01;
6'b111101: fullAdd_1_lut = 2'b11;
6'b011101: fullAdd_1_lut = 2'b01;
6'b101101: fullAdd_1_lut = 2'b01;
6'b110101: fullAdd_1_lut = 2'b01;
6'b010101: fullAdd_1_lut = 2'b01;
6'b100101: fullAdd_1_lut = 2'b01;
6'b111001: fullAdd_1_lut = 2'b01;
6'b011001: fullAdd_1_lut = 2'b01;
6'b101001: fullAdd_1_lut = 2'b10;
6'b111110: fullAdd_1_lut = 2'b01;
6'b011110: fullAdd_1_lut = 2'b01;
6'b101110: fullAdd_1_lut = 2'b01;
6'b110110: fullAdd_1_lut = 2'b01;
6'b010110: fullAdd_1_lut = 2'b01;
6'b100110: fullAdd_1_lut = 2'b10;
6'b111010: fullAdd_1_lut = 2'b01;
6'b011010: fullAdd_1_lut = 2'b10;
6'b101010: fullAdd_1_lut = 2'b10;
default: fullAdd_1_lut = 2'b00;
endcase
end
endfunction
function [1:0] halfAdd_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: halfAdd_0_lut = 2'b10;
6'b011111: halfAdd_0_lut = 2'b11;
6'b101111: halfAdd_0_lut = 2'b01;
6'b110111: halfAdd_0_lut = 2'b11;
6'b010111: halfAdd_0_lut = 2'b01;
6'b100111: halfAdd_0_lut = 2'b10;
6'b111011: halfAdd_0_lut = 2'b01;
6'b011011: halfAdd_0_lut = 2'b10;
6'b101011: halfAdd_0_lut = 2'b11;
6'b111101: halfAdd_0_lut = 2'b10;
6'b011101: halfAdd_0_lut = 2'b11;
6'b101101: halfAdd_0_lut = 2'b01;
6'b110101: halfAdd_0_lut = 2'b11;
6'b010101: halfAdd_0_lut = 2'b01;
6'b100101: halfAdd_0_lut = 2'b10;
6'b111001: halfAdd_0_lut = 2'b01;
6'b011001: halfAdd_0_lut = 2'b10;
6'b101001: halfAdd_0_lut = 2'b11;
6'b111110: halfAdd_0_lut = 2'b10;
6'b011110: halfAdd_0_lut = 2'b11;
6'b101110: halfAdd_0_lut = 2'b01;
6'b110110: halfAdd_0_lut = 2'b11;
6'b010110: halfAdd_0_lut = 2'b01;
6'b100110: halfAdd_0_lut = 2'b10;
6'b111010: halfAdd_0_lut = 2'b01;
6'b011010: halfAdd_0_lut = 2'b10;
6'b101010: halfAdd_0_lut = 2'b11;
default: halfAdd_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] halfAdd_1_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: halfAdd_1_lut = 2'b11;
6'b011111: halfAdd_1_lut = 2'b01;
6'b101111: halfAdd_1_lut = 2'b01;
6'b110111: halfAdd_1_lut = 2'b01;
6'b010111: halfAdd_1_lut = 2'b01;
6'b100111: halfAdd_1_lut = 2'b01;
6'b111011: halfAdd_1_lut = 2'b01;
6'b011011: halfAdd_1_lut = 2'b01;
6'b101011: halfAdd_1_lut = 2'b10;
6'b111101: halfAdd_1_lut = 2'b11;
6'b011101: halfAdd_1_lut = 2'b01;
6'b101101: halfAdd_1_lut = 2'b01;
6'b110101: halfAdd_1_lut = 2'b01;
6'b010101: halfAdd_1_lut = 2'b01;
6'b100101: halfAdd_1_lut = 2'b01;
6'b111001: halfAdd_1_lut = 2'b01;
6'b011001: halfAdd_1_lut = 2'b01;
6'b101001: halfAdd_1_lut = 2'b10;
6'b111110: halfAdd_1_lut = 2'b11;
6'b011110: halfAdd_1_lut = 2'b01;
6'b101110: halfAdd_1_lut = 2'b01;
6'b110110: halfAdd_1_lut = 2'b01;
6'b010110: halfAdd_1_lut = 2'b01;
6'b100110: halfAdd_1_lut = 2'b01;
6'b111010: halfAdd_1_lut = 2'b01;
6'b011010: halfAdd_1_lut = 2'b01;
6'b101010: halfAdd_1_lut = 2'b10;
default: halfAdd_1_lut = 2'b00;
endcase
end
endfunction
function [1:0] neg_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: neg_0_lut = 2'b10;
6'b011111: neg_0_lut = 2'b01;
6'b101111: neg_0_lut = 2'b11;
6'b110111: neg_0_lut = 2'b10;
6'b010111: neg_0_lut = 2'b01;
6'b100111: neg_0_lut = 2'b11;
6'b111011: neg_0_lut = 2'b10;
6'b011011: neg_0_lut = 2'b01;
6'b101011: neg_0_lut = 2'b11;
6'b111101: neg_0_lut = 2'b10;
6'b011101: neg_0_lut = 2'b01;
6'b101101: neg_0_lut = 2'b11;
6'b110101: neg_0_lut = 2'b10;
6'b010101: neg_0_lut = 2'b01;
6'b100101: neg_0_lut = 2'b11;
6'b111001: neg_0_lut = 2'b10;
6'b011001: neg_0_lut = 2'b01;
6'b101001: neg_0_lut = 2'b11;
6'b111110: neg_0_lut = 2'b10;
6'b011110: neg_0_lut = 2'b01;
6'b101110: neg_0_lut = 2'b11;
6'b110110: neg_0_lut = 2'b10;
6'b010110: neg_0_lut = 2'b01;
6'b100110: neg_0_lut = 2'b11;
6'b111010: neg_0_lut = 2'b10;
6'b011010: neg_0_lut = 2'b01;
6'b101010: neg_0_lut = 2'b11;
default: neg_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] sign_0_lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: sign_0_lut = 2'b11;
6'b011111: sign_0_lut = 2'b11;
6'b101111: sign_0_lut = 2'b11;
6'b110111: sign_0_lut = 2'b11;
6'b010111: sign_0_lut = 2'b11;
6'b100111: sign_0_lut = 2'b11;
6'b111011: sign_0_lut = 2'b11;
6'b011011: sign_0_lut = 2'b11;
6'b101011: sign_0_lut = 2'b11;
6'b111101: sign_0_lut = 2'b11;
6'b011101: sign_0_lut = 2'b11;
6'b101101: sign_0_lut = 2'b11;
6'b110101: sign_0_lut = 2'b11;
6'b010101: sign_0_lut = 2'b01;
6'b100101: sign_0_lut = 2'b10;
6'b111001: sign_0_lut = 2'b10;
6'b011001: sign_0_lut = 2'b10;
6'b101001: sign_0_lut = 2'b10;
6'b111110: sign_0_lut = 2'b10;
6'b011110: sign_0_lut = 2'b10;
6'b101110: sign_0_lut = 2'b10;
6'b110110: sign_0_lut = 2'b10;
6'b010110: sign_0_lut = 2'b10;
6'b100110: sign_0_lut = 2'b10;
6'b111010: sign_0_lut = 2'b10;
6'b011010: sign_0_lut = 2'b10;
6'b101010: sign_0_lut = 2'b10;
default: sign_0_lut = 2'b00;
endcase
end
endfunction
function [1:0] constZero__lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: constZero__lut = 2'b01;
6'b011111: constZero__lut = 2'b01;
6'b101111: constZero__lut = 2'b01;
6'b110111: constZero__lut = 2'b01;
6'b010111: constZero__lut = 2'b01;
6'b100111: constZero__lut = 2'b01;
6'b111011: constZero__lut = 2'b01;
6'b011011: constZero__lut = 2'b01;
6'b101011: constZero__lut = 2'b01;
6'b111101: constZero__lut = 2'b01;
6'b011101: constZero__lut = 2'b01;
6'b101101: constZero__lut = 2'b01;
6'b110101: constZero__lut = 2'b01;
6'b010101: constZero__lut = 2'b01;
6'b100101: constZero__lut = 2'b01;
6'b111001: constZero__lut = 2'b01;
6'b011001: constZero__lut = 2'b01;
6'b101001: constZero__lut = 2'b01;
6'b111110: constZero__lut = 2'b01;
6'b011110: constZero__lut = 2'b01;
6'b101110: constZero__lut = 2'b01;
6'b110110: constZero__lut = 2'b01;
6'b010110: constZero__lut = 2'b01;
6'b100110: constZero__lut = 2'b01;
6'b111010: constZero__lut = 2'b01;
6'b011010: constZero__lut = 2'b01;
6'b101010: constZero__lut = 2'b01;
default: constZero__lut = 2'b00;
endcase
end
endfunction
function [1:0] constOne__lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: constOne__lut = 2'b10;
6'b011111: constOne__lut = 2'b10;
6'b101111: constOne__lut = 2'b10;
6'b110111: constOne__lut = 2'b10;
6'b010111: constOne__lut = 2'b10;
6'b100111: constOne__lut = 2'b10;
6'b111011: constOne__lut = 2'b10;
6'b011011: constOne__lut = 2'b10;
6'b101011: constOne__lut = 2'b10;
6'b111101: constOne__lut = 2'b10;
6'b011101: constOne__lut = 2'b10;
6'b101101: constOne__lut = 2'b10;
6'b110101: constOne__lut = 2'b10;
6'b010101: constOne__lut = 2'b10;
6'b100101: constOne__lut = 2'b10;
6'b111001: constOne__lut = 2'b10;
6'b011001: constOne__lut = 2'b10;
6'b101001: constOne__lut = 2'b10;
6'b111110: constOne__lut = 2'b10;
6'b011110: constOne__lut = 2'b10;
6'b101110: constOne__lut = 2'b10;
6'b110110: constOne__lut = 2'b10;
6'b010110: constOne__lut = 2'b10;
6'b100110: constOne__lut = 2'b10;
6'b111010: constOne__lut = 2'b10;
6'b011010: constOne__lut = 2'b10;
6'b101010: constOne__lut = 2'b10;
default: constOne__lut = 2'b00;
endcase
end
endfunction
function [1:0] constMin__lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: constMin__lut = 2'b11;
6'b011111: constMin__lut = 2'b11;
6'b101111: constMin__lut = 2'b11;
6'b110111: constMin__lut = 2'b11;
6'b010111: constMin__lut = 2'b11;
6'b100111: constMin__lut = 2'b11;
6'b111011: constMin__lut = 2'b11;
6'b011011: constMin__lut = 2'b11;
6'b101011: constMin__lut = 2'b11;
6'b111101: constMin__lut = 2'b11;
6'b011101: constMin__lut = 2'b11;
6'b101101: constMin__lut = 2'b11;
6'b110101: constMin__lut = 2'b11;
6'b010101: constMin__lut = 2'b11;
6'b100101: constMin__lut = 2'b11;
6'b111001: constMin__lut = 2'b11;
6'b011001: constMin__lut = 2'b11;
6'b101001: constMin__lut = 2'b11;
6'b111110: constMin__lut = 2'b11;
6'b011110: constMin__lut = 2'b11;
6'b101110: constMin__lut = 2'b11;
6'b110110: constMin__lut = 2'b11;
6'b010110: constMin__lut = 2'b11;
6'b100110: constMin__lut = 2'b11;
6'b111010: constMin__lut = 2'b11;
6'b011010: constMin__lut = 2'b11;
6'b101010: constMin__lut = 2'b11;
default: constMin__lut = 2'b00;
endcase
end
endfunction
function [1:0] nullifyTrue__lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b101111: nullifyTrue__lut = 2'b11;
6'b100111: nullifyTrue__lut = 2'b01;
6'b101011: nullifyTrue__lut = 2'b10;
6'b101101: nullifyTrue__lut = 2'b11;
6'b100101: nullifyTrue__lut = 2'b01;
6'b101001: nullifyTrue__lut = 2'b10;
6'b101110: nullifyTrue__lut = 2'b11;
6'b100110: nullifyTrue__lut = 2'b01;
6'b101010: nullifyTrue__lut = 2'b10;
default: nullifyTrue__lut = 2'b00;
endcase
end
endfunction
function [1:0] nullifyFalse__lut(
input [1:0] p0
, input [1:0] p1
, input [1:0] p2
begin
case ({p0, p1, p2})
6'b111111: nullifyFalse__lut = 2'b11;
6'b110111: nullifyFalse__lut = 2'b01;
6'b111011: nullifyFalse__lut = 2'b10;
6'b111101: nullifyFalse__lut = 2'b11;
6'b110101: nullifyFalse__lut = 2'b01;
6'b111001: nullifyFalse__lut = 2'b10;
6'b111110: nullifyFalse__lut = 2'b11;
6'b110110: nullifyFalse__lut = 2'b01;
6'b111010: nullifyFalse__lut = 2'b10;
default: nullifyFalse__lut = 2'b00;
endcase
end
endfunction
function [1:0] cmp_1(
input [1:0] lhs
, input [1:0] rhs
begin
cmp_1 = cmp_0_lut(lhs, rhs, lhs);
end
endfunction
function [1:0] equal_1(
input [1:0] lhs
, input [1:0] rhs
begin
equal_1 = equal_0_lut(lhs, rhs, lhs);
end
endfunction
function [3:0] fullAdd_1(
input [1:0] lhs
, input [1:0] rhs
, input [1:0] carry
reg [1:0] v_3;
reg [1:0] v_4;
begin
v_3 = fullAdd_0_lut(lhs, rhs, carry);
v_4 = fullAdd_1_lut(lhs, rhs, carry);
fullAdd_1 = { v_3, v_4 };
end
endfunction
function [3:0] halfAdd_1(
input [1:0] val
, input [1:0] carry
reg [1:0] v_2;
reg [1:0] v_3;
begin
v_2 = halfAdd_0_lut(val, carry, val);
v_3 = halfAdd_1_lut(val, carry, val);
halfAdd_1 = { v_2, v_3 };
end
endfunction
function [1:0] neg_1(
input [1:0] val
begin
neg_1 = neg_0_lut(val, val, val);
end
endfunction
function [1:0] sign_1(
input [1:0] val
begin
sign_1 = val;
end
endfunction
function [5:0] constZero_3(
input [1:0] v_0
begin
constZero_3 = { constZero__lut(v_0, v_0, v_0), constZero__lut(v_0, v_0, v_0), constZero__lut(v_0, v_0, v_0) };
end
endfunction
function [17:0] constZero_9(
input [1:0] v_0
begin
constZero_9 = { constZero_3(v_0), constZero_3(v_0), constZero_3(v_0) };
end
endfunction
function [35:0] constZero_18(
input [1:0] v_0
begin
constZero_18 = { constZero_9(v_0), constZero_9(v_0) };
end
endfunction
function [11:0] constZero_6(
input [1:0] v_0
begin
constZero_6 = { constZero_3(v_0), constZero_3(v_0) };
end
endfunction
function [1:0] constZero_1(
input [1:0] v_0
begin
constZero_1 = constZero__lut(v_0, v_0, v_0);
end
endfunction
function [49:0] constZero_25(
input [1:0] v_0
begin
constZero_25 = { constZero_18(v_0), constZero_6(v_0), constZero_1(v_0) };
end
endfunction
function [53:0] const_27_T1(
input [1:0] v_0
reg [1:0] v_1;
reg [1:0] v_2;
reg [49:0] v_3;
begin
v_1 = constMin__lut(v_0, v_0, v_0);
v_2 = constOne__lut(v_0, v_0, v_0);
v_3 = constZero_25(v_0);
const_27_T1 = { v_1, v_2, v_3 };
end
endfunction
function [1:0] cmp_3(
input [5:0] lhs
, input [5:0] rhs
reg [1:0] v_2;
reg [1:0] v_3;
reg [1:0] val0;
reg [1:0] v_5;
reg [1:0] v_6;
reg [1:0] val1;
reg [1:0] v_8;
reg [1:0] v_9;
reg [1:0] val2;
begin
v_2 = lhs[5:4];
v_3 = rhs[5:4];
val0 = cmp_0_lut(v_2, v_3, v_2);
v_5 = lhs[3:2];
v_6 = rhs[3:2];
val1 = cmp_0_lut(v_5, v_6, v_5);
v_8 = lhs[1:0];
v_9 = rhs[1:0];
val2 = cmp_0_lut(v_8, v_9, v_8);
cmp_3 = sign_0_lut(val0, val1, val2);
end
endfunction
Observer dck140130
function [1:0] cmp_9(
input [17:0] lhs
, input [17:0] rhs
reg [5:0] v_2;
reg [5:0] v_3;
reg [1:0] val0;
reg [5:0] v_5;
reg [5:0] v_6;
reg [1:0] val1;
reg [5:0] v_8;
reg [5:0] v_9;
reg [1:0] val2;
begin
v_2 = lhs[17:12];
v_3 = rhs[17:12];
val0 = cmp_3(v_2, v_3);
v_5 = lhs[11:6];
v_6 = rhs[11:6];
val1 = cmp_3(v_5, v_6);
v_8 = lhs[5:0];
v_9 = rhs[5:0];
val2 = cmp_3(v_8, v_9);
cmp_9 = sign_0_lut(val0, val1, val2);
end
endfunction
function [1:0] cmp_27(
input [53:0] lhs
, input [53:0] rhs
reg [17:0] v_2;
reg [17:0] v_3;
reg [1:0] val0;
reg [17:0] v_5;
reg [17:0] v_6;
reg [1:0] val1;
reg [17:0] v_8;
reg [17:0] v_9;
reg [1:0] val2;
begin
v_2 = lhs[53:36];
v_3 = rhs[53:36];
val0 = cmp_9(v_2, v_3);
v_5 = lhs[35:18];
v_6 = rhs[35:18];
val1 = cmp_9(v_5, v_6);
v_8 = lhs[17:0];
v_9 = rhs[17:0];
val2 = cmp_9(v_8, v_9);
cmp_27 = sign_0_lut(val0, val1, val2);
end
endfunction
function [5:0] nullifyTrue_3(
input [1:0] v_0
, input [5:0] v_1
reg [1:0] v_2;
reg [1:0] v_3;
reg [1:0] v_4;
begin
v_2 = v_1[5:4];
v_3 = v_1[3:2];
v_4 = v_1[1:0];
nullifyTrue_3 = { nullifyTrue__lut(v_0, v_2, v_2), nullifyTrue__lut(v_0, v_3, v_3), nullifyTrue__lut(v_0, v_4, v_4) };
end
endfunction
function [17:0] nullifyTrue_9(
input [1:0] v_0
, input [17:0] v_1
reg [5:0] v_2;
reg [5:0] v_3;
reg [5:0] v_4;
begin
v_2 = v_1[17:12];
v_3 = v_1[11:6];
v_4 = v_1[5:0];
nullifyTrue_9 = { nullifyTrue_3(v_0, v_2), nullifyTrue_3(v_0, v_3), nullifyTrue_3(v_0, v_4) };
end
endfunction
function [53:0] nullifyTrue_27(
input [1:0] v_0
, input [53:0] v_1
reg [17:0] v_2;
reg [17:0] v_3;
reg [17:0] v_4;
begin
v_2 = v_1[53:36];
v_3 = v_1[35:18];
v_4 = v_1[17:0];
nullifyTrue_27 = { nullifyTrue_9(v_0, v_2), nullifyTrue_9(v_0, v_3), nullifyTrue_9(v_0, v_4) };
end
endfunction
function [5:0] nullifyFalse_3(
input [1:0] v_0
, input [5:0] v_1
reg [1:0] v_2;
reg [1:0] v_3;
reg [1:0] v_4;
begin
v_2 = v_1[5:4];
v_3 = v_1[3:2];
v_4 = v_1[1:0];
nullifyFalse_3 = { nullifyFalse__lut(v_0, v_2, v_2), nullifyFalse__lut(v_0, v_3, v_3), nullifyFalse__lut(v_0, v_4, v_4) };
end
endfunction
function [17:0] nullifyFalse_9(
input [1:0] v_0
, input [17:0] v_1
reg [5:0] v_2;
reg [5:0] v_3;
reg [5:0] v_4;
begin
v_2 = v_1[17:12];
v_3 = v_1[11:6];
v_4 = v_1[5:0];
nullifyFalse_9 = { nullifyFalse_3(v_0, v_2), nullifyFalse_3(v_0, v_3), nullifyFalse_3(v_0, v_4) };
end
endfunction
function [53:0] nullifyFalse_27(
input [1:0] v_0
, input [53:0] v_1
reg [17:0] v_2;
reg [17:0] v_3;
reg [17:0] v_4;
begin
v_2 = v_1[53:36];
v_3 = v_1[35:18];
v_4 = v_1[17:0];
nullifyFalse_27 = { nullifyFalse_9(v_0, v_2), nullifyFalse_9(v_0, v_3), nullifyFalse_9(v_0, v_4) };
end
endfunction
function [1:0] const_1_T(
input [1:0] v_0
reg [1:0] v_1;
begin
const_1_T = v_1;
end
endfunction
function [7:0] halfAdd_3(
input [5:0] val
, input [1:0] carry
reg [1:0] v_2;
reg [3:0] add0;
reg [1:0] v_4;
reg [1:0] v_5;
reg [3:0] add1;
reg [1:0] v_7;
reg [1:0] v_8;
reg [3:0] add2;
reg [1:0] v_10;
reg [1:0] v_11;
begin
v_2 = val[5:4];
add0 = halfAdd_1(v_2, carry);
v_4 = val[3:2];
v_5 = add0[1:0];
add1 = halfAdd_1(v_4, v_5);
v_7 = val[1:0];
v_8 = add1[1:0];
add2 = halfAdd_1(v_7, v_8);
v_10 = add0[3:2];
v_11 = add1[3:2];
halfAdd_3 = { v_10, v_11, add2 };
end
endfunction
function [19:0] halfAdd_9(
input [17:0] val
, input [1:0] carry
reg [5:0] v_2;
reg [7:0] add0;
reg [5:0] v_4;
reg [1:0] v_5;
reg [7:0] add1;
reg [5:0] v_7;
reg [1:0] v_8;
reg [7:0] add2;
reg [5:0] v_10;
reg [5:0] v_11;
begin
v_2 = val[17:12];
add0 = halfAdd_3(v_2, carry);
v_4 = val[11:6];
v_5 = add0[1:0];
add1 = halfAdd_3(v_4, v_5);
v_7 = val[5:0];
v_8 = add1[1:0];
add2 = halfAdd_3(v_7, v_8);
v_10 = add0[7:2];
v_11 = add1[7:2];
halfAdd_9 = { v_10, v_11, add2 };
end
endfunction
function [55:0] halfAdd_27(
input [53:0] val
, input [1:0] carry
reg [17:0] v_2;
reg [19:0] add0;
reg [17:0] v_4;
reg [1:0] v_5;
reg [19:0] add1;
reg [17:0] v_7;
reg [1:0] v_8;
reg [19:0] add2;
reg [17:0] v_10;
reg [17:0] v_11;
begin
v_2 = val[53:36];
add0 = halfAdd_9(v_2, carry);
v_4 = val[35:18];
v_5 = add0[1:0];
add1 = halfAdd_9(v_4, v_5);
v_7 = val[17:0];
v_8 = add1[1:0];
add2 = halfAdd_9(v_7, v_8);
v_10 = add0[19:2];
v_11 = add1[19:2];
halfAdd_27 = { v_10, v_11, add2 };
end
endfunction
function [53:0] decr_27(
input [53:0] val
reg [1:0] v_1;
reg [55:0] halfSum;
begin
v_1 = const_1_T(val[1:0]);
halfSum = halfAdd_27(val, v_1);
decr_27 = halfSum[55:2];
end
endfunction
function [5:0] neg_3(
input [5:0] val
reg [1:0] v_1;
reg [1:0] val0;
reg [1:0] v_3;
reg [1:0] val1;
reg [1:0] v_5;
reg [1:0] val2;
begin
v_1 = val[5:4];
val0 = neg_0_lut(v_1, v_1, v_1);
v_3 = val[3:2];
val1 = neg_0_lut(v_3, v_3, v_3);
v_5 = val[1:0];
val2 = neg_0_lut(v_5, v_5, v_5);
neg_3 = { val0, val1, val2 };
end
endfunction
function [17:0] neg_9(
input [17:0] val
reg [5:0] v_1;
reg [5:0] val0;
reg [5:0] v_3;
reg [5:0] val1;
reg [5:0] v_5;
reg [5:0] val2;
begin
v_1 = val[17:12];
val0 = neg_3(v_1);
v_3 = val[11:6];
val1 = neg_3(v_3);
v_5 = val[5:0];
val2 = neg_3(v_5);
neg_9 = { val0, val1, val2 };
end
endfunction
function [53:0] neg_27(
input [53:0] val
reg [17:0] v_1;
reg [17:0] val0;
reg [17:0] v_3;
reg [17:0] val1;
reg [17:0] v_5;
reg [17:0] val2;
begin
v_1 = val[53:36];
val0 = neg_9(v_1);
v_3 = val[35:18];
val1 = neg_9(v_3);
v_5 = val[17:0];
val2 = neg_9(v_5);
neg_27 = { val0, val1, val2 };
end
endfunction
function [7:0] fullAdd_3(
input [5:0] lhs
, input [5:0] rhs
, input [1:0] carry
reg [1:0] v_3;
reg [1:0] v_4;
reg [3:0] add0;
reg [1:0] v_6;
reg [1:0] v_7;
reg [1:0] v_8;
reg [3:0] add1;
reg [1:0] v_10;
reg [1:0] v_11;
reg [1:0] v_12;
reg [3:0] add2;
reg [1:0] v_14;
reg [1:0] v_15;
begin
v_3 = lhs[5:4];
v_4 = rhs[5:4];
add0 = fullAdd_1(v_3, v_4, carry);
v_6 = lhs[3:2];
v_7 = rhs[3:2];
v_8 = add0[1:0];
add1 = fullAdd_1(v_6, v_7, v_8);
v_10 = lhs[1:0];
v_11 = rhs[1:0];
v_12 = add1[1:0];
add2 = fullAdd_1(v_10, v_11, v_12);
v_14 = add0[3:2];
v_15 = add1[3:2];
fullAdd_3 = { v_14, v_15, add2 };
end
endfunction
function [19:0] fullAdd_9(
input [17:0] lhs
, input [17:0] rhs
, input [1:0] carry
reg [5:0] v_3;
reg [5:0] v_4;
reg [7:0] add0;
reg [5:0] v_6;
reg [5:0] v_7;
reg [1:0] v_8;
reg [7:0] add1;
reg [5:0] v_10;
reg [5:0] v_11;
reg [1:0] v_12;
reg [7:0] add2;
reg [5:0] v_14;
reg [5:0] v_15;
begin
v_3 = lhs[17:12];
v_4 = rhs[17:12];
add0 = fullAdd_3(v_3, v_4, carry);
v_6 = lhs[11:6];
v_7 = rhs[11:6];
v_8 = add0[1:0];
add1 = fullAdd_3(v_6, v_7, v_8);
v_10 = lhs[5:0];
v_11 = rhs[5:0];
v_12 = add1[1:0];
add2 = fullAdd_3(v_10, v_11, v_12);
v_14 = add0[7:2];
v_15 = add1[7:2];
fullAdd_9 = { v_14, v_15, add2 };
end
endfunction
function [55:0] fullAdd_27(
input [53:0] lhs
, input [53:0] rhs
, input [1:0] carry
reg [17:0] v_3;
reg [17:0] v_4;
reg [19:0] add0;
reg [17:0] v_6;
reg [17:0] v_7;
reg [1:0] v_8;
reg [19:0] add1;
reg [17:0] v_10;
reg [17:0] v_11;
reg [1:0] v_12;
reg [19:0] add2;
reg [17:0] v_14;
reg [17:0] v_15;
begin
v_3 = lhs[53:36];
v_4 = rhs[53:36];
add0 = fullAdd_9(v_3, v_4, carry);
v_6 = lhs[35:18];
v_7 = rhs[35:18];
v_8 = add0[1:0];
add1 = fullAdd_9(v_6, v_7, v_8);
v_10 = lhs[17:0];
v_11 = rhs[17:0];
v_12 = add1[1:0];
add2 = fullAdd_9(v_10, v_11, v_12);
v_14 = add0[19:2];
v_15 = add1[19:2];
fullAdd_27 = { v_14, v_15, add2 };
end
endfunction
function [53:0] sub_27(
input [53:0] lhs
, input [53:0] rhs
reg [53:0] v_2;
reg [1:0] v_3;
reg [55:0] sum;
begin
v_2 = neg_27(rhs);
v_3 = constZero_1(lhs[1:0]);
sum = fullAdd_27(lhs, v_2, v_3);
sub_27 = sum[55:2];
end
endfunction
function [53:0] add_27(
input [53:0] lhs
, input [53:0] rhs
reg [1:0] v_2;
reg [55:0] sum;
begin
v_2 = constZero_1(lhs[1:0]);
sum = fullAdd_27(lhs, rhs, v_2);
add_27 = sum[55:2];
end
endfunction
function automatic [53:0] fibonacci1_27(
input [53:0] n
reg [53:0] v_1;
reg [1:0] v_2;
reg [1:0] retN;
reg [53:0] v_4;
reg [53:0] v_5;
reg [53:0] nMin1;
reg [53:0] v_7;
reg [53:0] v_8;
reg [53:0] v_9;
reg [53:0] v_10;
reg [53:0] nMin2;
reg [53:0] v_12;
reg [53:0] v_13;
begin
v_1 = const_27_T1(n[1:0]);
v_2 = cmp_27(n, v_1);
retN = isLess_0_lut(v_2, v_2, v_2);
v_4 = nullifyTrue_27(retN, n);
v_5 = nullifyFalse_27(retN, n);
nMin1 = decr_27(v_5);
v_7 = fibonacci1_27(nMin1);
v_8 = nullifyFalse_27(retN, n);
v_9 = const_27_T1(n[1:0]);
v_10 = nullifyFalse_27(retN, v_9);
nMin2 = sub_27(v_8, v_10);
v_12 = fibonacci1_27(nMin2);
v_13 = add_27(v_7, v_12);
fibonacci1_27 = merge__27(v_4, v_13);
end
endfunction
function [53:0] constZero_27(
input [1:0] v_0
begin
constZero_27 = { constZero_9(v_0), constZero_9(v_0), constZero_9(v_0) };
end
endfunction
function [51:0] constZero_26(
input [1:0] v_0
begin
constZero_26 = { constZero_25(v_0), constZero_1(v_0) };
end
endfunction
function [53:0] const_27_1(
input [1:0] v_0
reg [1:0] v_1;
reg [51:0] v_2;
begin
v_1 = constOne__lut(v_0, v_0, v_0);
v_2 = constZero_26(v_0);
const_27_1 = { v_1, v_2 };
end
endfunction
function [1:0] sign_3(
input [5:0] val
reg [1:0] v_1;
reg [1:0] v_2;
reg [1:0] v_3;
begin
v_1 = val[5:4];
v_2 = val[3:2];
v_3 = val[1:0];
sign_3 = sign_0_lut(v_1, v_2, v_3);
end
endfunction
function [1:0] sign_9(
input [17:0] val
reg [5:0] v_1;
reg [1:0] val0;
reg [5:0] v_3;
reg [1:0] val1;
reg [5:0] v_5;
reg [1:0] val2;
begin
v_1 = val[17:12];
val0 = sign_3(v_1);
v_3 = val[11:6];
val1 = sign_3(v_3);
v_5 = val[5:0];
val2 = sign_3(v_5);
sign_9 = sign_0_lut(val0, val1, val2);
end
endfunction
function [1:0] sign_27(
input [53:0] val
reg [17:0] v_1;
reg [1:0] val0;
reg [17:0] v_3;
reg [1:0] val1;
reg [17:0] v_5;
reg [1:0] val2;
begin
v_1 = val[53:36];
val0 = sign_9(v_1);
v_3 = val[35:18];
val1 = sign_9(v_3);
v_5 = val[17:0];
val2 = sign_9(v_5);
sign_27 = sign_0_lut(val0, val1, val2);
end
endfunction
function automatic [53:0] fibPart2_27(
input [53:0] n
, input [53:0] fib0
, input [53:0] fib1
reg [1:0] v_3;
reg [1:0] retFib2;
reg [53:0] fib2;
reg [53:0] v_6;
reg [53:0] v_7;
reg [53:0] v_8;
reg [53:0] v_9;
reg [53:0] v_10;
reg [53:0] v_11;
begin
v_3 = sign_27(n);
retFib2 = isZero_0_lut(v_3, v_3, v_3);
fib2 = add_27(fib0, fib1);
v_6 = nullifyTrue_27(retFib2, fib2);
v_7 = nullifyFalse_27(retFib2, n);
v_8 = decr_27(v_7);
v_9 = nullifyFalse_27(retFib2, fib1);
v_10 = nullifyFalse_27(retFib2, fib2);
v_11 = fibPart2_27(v_8, v_9, v_10);
fibPart2_27 = merge__27(v_6, v_11);
end
endfunction
function [53:0] fibonacci2_27(
input [53:0] n
reg [53:0] v_1;
reg [1:0] v_2;
reg [1:0] retN;
reg [53:0] v_4;
reg [53:0] v_5;
reg [53:0] v_6;
reg [53:0] v_7;
reg [53:0] v_8;
reg [53:0] v_9;
reg [53:0] v_10;
reg [53:0] v_11;
reg [53:0] v_12;
reg [53:0] v_13;
begin
v_6 = const_27_T1(n[1:0]);
v_7 = nullifyFalse_27(retN, v_6);
v_8 = sub_27(v_5, v_7);
v_9 = constZero_27(n[1:0]);
v_11 = const_27_1(n[1:0]);
v_12 = nullifyFalse_27(retN, v_11);
v_13 = fibPart2_27(v_8, v_10, v_12);
fibonacci2_27 = merge__27(v_4, v_13);
end
endfunction
function [107:0] constZero_54(
input [1:0] v_0
begin
constZero_54 = { constZero_27(v_0), constZero_27(v_0) };
end
endfunction
function [157:0] constZero_79(
input [1:0] v_0
begin
constZero_79 = { constZero_54(v_0), constZero_25(v_0) };
end
endfunction
function [161:0] const_81_T1(
input [1:0] v_0
reg [1:0] v_1;
reg [1:0] v_2;
reg [157:0] v_3;
begin
v_3 = constZero_79(v_0);
const_81_T1 = { v_1, v_2, v_3 };
end
endfunction
function [1:0] cmp_81(
input [161:0] lhs
, input [161:0] rhs
reg [53:0] v_2;
reg [53:0] v_3;
reg [1:0] val0;
reg [53:0] v_5;
reg [53:0] v_6;
reg [1:0] val1;
reg [53:0] v_8;
reg [53:0] v_9;
reg [1:0] val2;
begin
v_2 = lhs[161:108];
v_3 = rhs[161:108];
val0 = cmp_27(v_2, v_3);
v_5 = lhs[107:54];
v_6 = rhs[107:54];
val1 = cmp_27(v_5, v_6);
v_8 = lhs[53:0];
v_9 = rhs[53:0];
val2 = cmp_27(v_8, v_9);
cmp_81 = sign_0_lut(val0, val1, val2);
end
endfunction
function [161:0] nullifyTrue_81(
input [1:0] v_0
, input [161:0] v_1
reg [53:0] v_2;
reg [53:0] v_3;
reg [53:0] v_4;
begin
v_2 = v_1[161:108];
v_3 = v_1[107:54];
v_4 = v_1[53:0];
nullifyTrue_81 = { nullifyTrue_27(v_0, v_2), nullifyTrue_27(v_0, v_3), nullifyTrue_27(v_0, v_4) };
end
endfunction
function [161:0] nullifyFalse_81(
input [1:0] v_0
, input [161:0] v_1
reg [53:0] v_2;
reg [53:0] v_3;
reg [53:0] v_4;
begin
v_2 = v_1[161:108];
v_3 = v_1[107:54];
v_4 = v_1[53:0];
nullifyFalse_81 = { nullifyFalse_27(v_0, v_2), nullifyFalse_27(v_0, v_3), nullifyFalse_27(v_0, v_4) };
end
endfunction
function [161:0] neg_81(
input [161:0] val
reg [53:0] v_1;
reg [53:0] val0;
reg [53:0] v_3;
reg [53:0] val1;
reg [53:0] v_5;
reg [53:0] val2;
begin
v_1 = val[161:108];
val0 = neg_27(v_1);
v_3 = val[107:54];
val1 = neg_27(v_3);
v_5 = val[53:0];
val2 = neg_27(v_5);
neg_81 = { val0, val1, val2 };
end
endfunction
function [163:0] fullAdd_81(
input [161:0] lhs
, input [161:0] rhs
, input [1:0] carry
reg [53:0] v_3;
reg [53:0] v_4;
reg [55:0] add0;
reg [53:0] v_6;
reg [53:0] v_7;
reg [1:0] v_8;
reg [55:0] add1;
reg [53:0] v_10;
reg [53:0] v_11;
reg [1:0] v_12;
reg [55:0] add2;
reg [53:0] v_14;
reg [53:0] v_15;
begin
v_3 = lhs[161:108];
v_4 = rhs[161:108];
add0 = fullAdd_27(v_3, v_4, carry);
v_6 = lhs[107:54];
v_7 = rhs[107:54];
v_8 = add0[1:0];
add1 = fullAdd_27(v_6, v_7, v_8);
v_10 = lhs[53:0];
v_11 = rhs[53:0];
v_12 = add1[1:0];
add2 = fullAdd_27(v_10, v_11, v_12);
v_14 = add0[55:2];
v_15 = add1[55:2];
fullAdd_81 = { v_14, v_15, add2 };
end
endfunction
function [161:0] sub_81(
input [161:0] lhs
, input [161:0] rhs
reg [161:0] v_2;
reg [1:0] v_3;
reg [163:0] sum;
begin
v_2 = neg_81(rhs);
sum = fullAdd_81(lhs, v_2, v_3);
sub_81 = sum[163:2];
end
endfunction
function [161:0] constZero_81(
input [1:0] v_0
begin
constZero_81 = { constZero_27(v_0), constZero_27(v_0), constZero_27(v_0) };
end
endfunction
function [159:0] constZero_80(
input [1:0] v_0
begin
constZero_80 = { constZero_79(v_0), constZero_1(v_0) };
end
endfunction
function [161:0] const_81_1(
input [1:0] v_0
reg [1:0] v_1;
reg [159:0] v_2;
begin
v_2 = constZero_80(v_0);
const_81_1 = { v_1, v_2 };
end
endfunction
function [1:0] sign_81(
input [161:0] val
reg [53:0] v_1;
reg [1:0] val0;
reg [53:0] v_3;
reg [1:0] val1;
reg [53:0] v_5;
reg [1:0] val2;
begin
v_1 = val[161:108];
val0 = sign_27(v_1);
v_3 = val[107:54];
val1 = sign_27(v_3);
v_5 = val[53:0];
val2 = sign_27(v_5);
sign_81 = sign_0_lut(val0, val1, val2);
end
endfunction
function [161:0] add_81(
input [161:0] lhs
, input [161:0] rhs
reg [1:0] v_2;
reg [163:0] sum;
begin
sum = fullAdd_81(lhs, rhs, v_2);
add_81 = sum[163:2];
end
endfunction
function [163:0] halfAdd_81(
input [161:0] val
, input [1:0] carry
reg [53:0] v_2;
reg [55:0] add0;
reg [53:0] v_4;
reg [1:0] v_5;
reg [55:0] add1;
reg [53:0] v_7;
reg [1:0] v_8;
reg [55:0] add2;
reg [53:0] v_10;
reg [53:0] v_11;
begin
v_2 = val[161:108];
add0 = halfAdd_27(v_2, carry);
v_4 = val[107:54];
v_5 = add0[1:0];
add1 = halfAdd_27(v_4, v_5);
v_7 = val[53:0];
v_8 = add1[1:0];
add2 = halfAdd_27(v_7, v_8);
v_10 = add0[55:2];
v_11 = add1[55:2];
halfAdd_81 = { v_10, v_11, add2 };
end
endfunction
function [161:0] decr_81(
input [161:0] val
reg [1:0] v_1;
reg [163:0] halfSum;
begin
halfSum = halfAdd_81(val, v_1);
decr_81 = halfSum[163:2];
end
endfunction
function automatic [161:0] fibPart2_81(
input [161:0] n
, input [161:0] fib0
, input [161:0] fib1
reg [1:0] v_3;
reg [1:0] retFib2;
reg [161:0] fib2;
reg [161:0] v_6;
reg [161:0] v_7;
reg [161:0] v_8;
reg [161:0] v_9;
reg [161:0] v_10;
reg [161:0] v_11;
begin
v_3 = sign_81(n);
fib2 = add_81(fib0, fib1);
v_6 = nullifyTrue_81(retFib2, fib2);
v_7 = nullifyFalse_81(retFib2, n);
v_8 = decr_81(v_7);
v_9 = nullifyFalse_81(retFib2, fib1);
v_10 = nullifyFalse_81(retFib2, fib2);
v_11 = fibPart2_81(v_8, v_9, v_10);
fibPart2_81 = merge__81(v_6, v_11);
end
endfunction
function automatic [161:0] fibonacci2_81(
input [161:0] n
reg [161:0] v_1;
reg [1:0] v_2;
reg [1:0] retN;
reg [161:0] v_4;
reg [161:0] v_5;
reg [161:0] v_6;
reg [161:0] v_7;
reg [161:0] v_8;
reg [161:0] v_9;
reg [161:0] v_10;
reg [161:0] v_11;
reg [161:0] v_12;
reg [161:0] v_13;
begin
v_1 = const_81_T1(n[1:0]);
v_2 = cmp_81(n, v_1);
v_4 = nullifyTrue_81(retN, n);
v_5 = nullifyFalse_81(retN, n);
v_6 = const_81_T1(n[1:0]);
v_7 = nullifyFalse_81(retN, v_6);
v_8 = sub_81(v_5, v_7);
v_9 = constZero_81(n[1:0]);
v_10 = nullifyFalse_81(retN, v_9);
v_11 = const_81_1(n[1:0]);
v_12 = nullifyFalse_81(retN, v_11);
v_13 = fibPart2_81(v_8, v_10, v_12);
fibonacci2_81 = merge__81(v_4, v_13);
end
endfunction
function [3:0] constZero_2(
input [1:0] v_0
begin
constZero_2 = { constZero__lut(v_0, v_0, v_0), constZero__lut(v_0, v_0, v_0) };
end
endfunction
function [1:0] nullifyTrue_1(
input [1:0] v_0
, input [1:0] v_1
begin
nullifyTrue_1 = nullifyTrue__lut(v_0, v_1, v_1);
end
endfunction
function [3:0] nullifyTrue_2(
input [1:0] v_0
, input [3:0] v_1
reg [1:0] v_2;
reg [1:0] v_3;
begin
v_2 = v_1[3:2];
v_3 = v_1[1:0];
nullifyTrue_2 = { nullifyTrue__lut(v_0, v_2, v_2), nullifyTrue__lut(v_0, v_3, v_3) };
end
endfunction
function [11:0] nullifyTrue_6(
input [1:0] v_0
, input [11:0] v_1
reg [5:0] v_2;
reg [5:0] v_3;
begin
v_2 = v_1[11:6];
v_3 = v_1[5:0];
nullifyTrue_6 = { nullifyTrue_3(v_0, v_2), nullifyTrue_3(v_0, v_3) };
end
endfunction
function [35:0] nullifyTrue_18(
input [1:0] v_0
, input [35:0] v_1
reg [17:0] v_2;
reg [17:0] v_3;
begin
v_2 = v_1[35:18];
v_3 = v_1[17:0];
nullifyTrue_18 = { nullifyTrue_9(v_0, v_2), nullifyTrue_9(v_0, v_3) };
end
endfunction
function [107:0] nullifyTrue_54(
input [1:0] v_0
, input [107:0] v_1
reg [53:0] v_2;
reg [53:0] v_3;
begin
v_2 = v_1[107:54];
v_3 = v_1[53:0];
nullifyTrue_54 = { nullifyTrue_27(v_0, v_2), nullifyTrue_27(v_0, v_3) };
end
endfunction
function [1:0] nullifyFalse_1(
input [1:0] v_0
, input [1:0] v_1
begin
nullifyFalse_1 = nullifyFalse__lut(v_0, v_1, v_1);
end
endfunction
function [3:0] nullifyFalse_2(
input [1:0] v_0
, input [3:0] v_1
reg [1:0] v_2;
reg [1:0] v_3;
begin
v_2 = v_1[3:2];
v_3 = v_1[1:0];
nullifyFalse_2 = { nullifyFalse__lut(v_0, v_2, v_2), nullifyFalse__lut(v_0, v_3, v_3) };
end
endfunction
function [11:0] nullifyFalse_6(
input [1:0] v_0
, input [11:0] v_1
reg [5:0] v_2;
reg [5:0] v_3;
begin
v_2 = v_1[11:6];
v_3 = v_1[5:0];
nullifyFalse_6 = { nullifyFalse_3(v_0, v_2), nullifyFalse_3(v_0, v_3) };
end
endfunction
function [35:0] nullifyFalse_18(
input [1:0] v_0
, input [35:0] v_1
reg [17:0] v_2;
reg [17:0] v_3;
begin
v_2 = v_1[35:18];
v_3 = v_1[17:0];
nullifyFalse_18 = { nullifyFalse_9(v_0, v_2), nullifyFalse_9(v_0, v_3) };
end
endfunction
function [107:0] nullifyFalse_54(
input [1:0] v_0
, input [107:0] v_1
reg [53:0] v_2;
reg [53:0] v_3;
begin
v_2 = v_1[107:54];
v_3 = v_1[53:0];
nullifyFalse_54 = { nullifyFalse_27(v_0, v_2), nullifyFalse_27(v_0, v_3) };
end
endfunction
function [1:0] merge__1(
input [1:0] input1
, input [1:0] input2
begin
case ({input1, input2})
4'b0000: merge__1 = 2'b00;
4'b0001: merge__1 = 2'b01;
4'b0010: merge__1 = 2'b10;
4'b0011: merge__1 = 2'b11;
4'b0100: merge__1 = 2'b01;
4'b1000: merge__1 = 2'b10;
4'b1100: merge__1 = 2'b11;
4'b0101: merge__1 = 2'b01;
4'b1010: merge__1 = 2'b10;
4'b1111: merge__1 = 2'b11;
default: begin
merge__1 = 2'b00;
x = 1;
end
endcase
end
endfunction
function [5:0] merge__3(
input [5:0] input1
, input [5:0] input2
reg [1:0] p0;
reg [1:0] p1;
reg [1:0] p2;
begin
p0 = merge__1(input1[5:4], input2[5:4]);
p1 = merge__1(input1[3:2], input2[3:2]);
p2 = merge__1(input1[1:0], input2[1:0]);
merge__3 = { p0, p1, p2 };
end
endfunction
function [17:0] merge__9(
input [17:0] input1
, input [17:0] input2
reg [5:0] p0;
reg [5:0] p1;
reg [5:0] p2;
begin
p0 = merge__3(input1[17:12], input2[17:12]);
p1 = merge__3(input1[11:6], input2[11:6]);
p2 = merge__3(input1[5:0], input2[5:0]);
merge__9 = { p0, p1, p2 };
end
endfunction
function [53:0] merge__27(
input [53:0] input1
, input [53:0] input2
reg [17:0] p0;
reg [17:0] p1;
reg [17:0] p2;
begin
p0 = merge__9(input1[53:36], input2[53:36]);
p1 = merge__9(input1[35:18], input2[35:18]);
p2 = merge__9(input1[17:0], input2[17:0]);
merge__27 = { p0, p1, p2 };
end
endfunction
function [161:0] merge__81(
input [161:0] input1
, input [161:0] input2
reg [53:0] p0;
reg [53:0] p1;
reg [53:0] p2;
begin
p0 = merge__27(input1[161:108], input2[161:108]);
p1 = merge__27(input1[107:54], input2[107:54]);
p2 = merge__27(input1[53:0], input2[53:0]);
merge__81 = { p0, p1, p2 };
end
endfunction
Scholar markcurry
@dck140130
Can you simplify your example? - it's really much too large to diagnose in such a forum.  I can't even quickly pick our where the recursion is.
Mark
Observer dck140130
Thank you for taking a look Mark, I will work something simplified up after Thursday :-)
Hi @dck140130,
I have sent you ezmove ftp testpackage. Through which you can provide your archived project. So we can investigate it further.
hemangd
Observer dck140130
Thank you,
Working on this now.
