I wanna believe, but....
I'm seeing these kinds of complaints a lot.  They do not make sense after doing block refresh and verify design without error.
Hi @srdatucsd
Ok. I never used this different views.
So I am able to reproduce the warning but only if I connect the pin between 2 inputs:
So it takes sense in this case.
Each time I connect an output port to drive this pin, the warning disappear.
So if you have a test case with the port correctly driver but vivado still producing a warning, please package your project so I can analyze it
Florent
@srdatucsd ,
I can't read your image.  What types of complaints are you talking about?
Dan
Guide
Guide
If you click on an image, it appears in a pop-up window in the browser. In this view it is no larger than the original image. However, in the top right corner of the pop-up there is a button to expand the image to full screen. Using this, the image (including the error message) is readable.
Avrum
HI @srdatucsd
What version are you using?
Do you have any test case to share (should be easy to reproduce but a test case would be faster)
Florent
@srdatucsd ,
If you do not explain your problem, so we can only make speculations.
This is what I could make out from your screenshot...
3 input ports in your design are unconnected and so Vivado flags a Critical Warning message. Check if they should be this way and correct it. If they are unused, just remove them to proceed with Synth.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
I'm using 2019.2
I thought the screenshot to be self-explanatory.  It says things are not connected in the error messages, that are obviously connected - unless the IP diagram is a lie.  The RTL has the proper ports as well.  I do not have a test case and do not know how to create one for a VIvado bug like this.
HI @srdatucsd
One thing which is strange is the view of the IP. This is what I have in vivado 2019.2:
As you can see, all the ports which are supposed to be inputs of the IPs are on the left (including aux_reset_in) and all the port which are outputs are on the right.
Also, even if it stays unconnected, I do not get any warning...
Did you change anything in the settings of vivado which might give this? What OS are you using?
Can you send a test case?
And can you send me the txt file output from report_environment -file Env.txt ?
Florent
If you play with the block display options, say to remove loops, it will shuffle inputs and outputs around in ways that 'make sense' to the programmer of the graphical interface.  I have no control over where things end up for clarity as a hardware designer.    Inputs can be on the right and I think outputs can be on the left.  I cannot even control the IP block placement grid.
That is the only thing I knowingly changed other than trying different routing strategies.  I am unable to send a test case.  I have moved on from this problem (critical schedule to meet) as It cured itself after multiple changes and re-imps.  If I can ever find that file you requested, I'll send it, but I think it is gone.  It seems a problem that Xilinx should be interested in solving though, and I will report here if/when it returns.
I am running on Ubuntu 16.04 for 2019.2.
Thanks for taking the anomaly seriously.
Hi @srdatucsd
Florent
Will do.  Mine is driven for sure.  To be continued on recurrence.
P.S.  I'm finding packaging a project a daunting task, i.e., to generate the TCL that would recreate it.  For example, write_bd_tcl leaves too much to figure out after the fact and the latter is error prone.
But that is a different issue.
