Image Enhancement IP Core Issue
   I am using Image enhancement IP Core in my design, but while generating bit stream I am finding this error. I think its because of license error but not sure. If so how can I get the license. Can anyone help me out. I am getting the error as below.
Devdatt
Re: Image Enhancement IP Core Issue
@devdattbhat,
Yes, Looks like license error for Image enhancement IP.
Do you have valid license for this IP?  If no, then You can purchase the full License by contacting our sales representative:
https://www.xilinx.com/about/contact/sales-reps.html
You can also generate Hardware evaluation license of this IP by clicking on Evaluate in below link.
https://www.xilinx.com/products/intellectual-property/ef-di-img-enhance.html
FYI: Hardware Evaluation License will allow you to also generate implementation netlists and bitstreams that you can use to program an FPGA device and evaluate the core in hardware for some number of hours
Make sure you regenerate the IP output products of this project in vivado after setting up the license.
--Syed
@devdattbhat
Please contact your FAE to get details on license purchase process.
Anusheel
Helpful answer -> Give Kudos
