Observer aparna
Importing a file and using its values in XILINX
I am working on this project in which half my code is in MATLAB and half is in VHDL.
The MATLAB code produces a .txt file.
Is there a way to import this .txt file and use it in my vhdl code in xilinx?
If so how do I do it and how can I access individual values from the file?
Re: Importing a file and using its values in XILINX
yes i think it is beacuse you cannot synthesise this code.
You can only simulate it. This is NOT code you can use on an FPGA. You will need modelsim, activeHDL, GHDL or some other simulator like MODELSIM to see this working. File IO is intended for testing and behavioural models only.
Presumably, you're trying to use the .txt file as testbench stimulus.
Spend some time on google or a textbook for VHDL file I/O.
Here's one example:
http://www.stefanvhdl.com/vhdl/html/file_read.html
www.xilinx.com
Observer aparna
This example is not working. There is an error:
HDLCompiler:1316 - "D:/code/fileread/file_read.vhd" Line 51: Index value <0> is out of range [1:2147483647] of array <string>
can you tell me how to fix this as online is says that the range of the string is wrong.
i had tried synthesizing your code & it seems you should use "use work.txt_util.all;" this library in FILE_READ.vhd file.
Also make sure that you have created/or "use work.txt_util.all;"  library is present in your project environment.
Observer aparna
"use work.txt_util.all " has been added, but it still gives the same error.
The only thing now i can guess is
strings have to be declared with natural ranges, and always ascending.
 so you have to declare: variable s : string(1 to 10); NOT string(0 to 9);
Actually you should modify variable s: string(y'range);  variable s : string(1 to 6);
After this I tried again it shows "ERROR:Xst:842 - "E:/voip_ise/FILE_READ.vhd" line 47: Same wait conditions expected in all Multiple Waits."
So now you need to add wait at the end of the process, else it will loop forever. Im guessing you only want it to run once.
after i wrote wait; statement it gives me the following error. ERROR:Xst:841 - "C:/Design_path/test.vhd" line 47: Bad condition in wait statement, or only one clock per process.
Observer aparna
thanks a ton!
