Increasing wire delay by changing type of wire
In one of my design I want to increase wire or channel delay between two inverters in my design by selecting type of wire between them.
How this can be done. Please let me know?
Re: Increasing wire delay by changing type of wire
@vinayak_sasken123 the easiest option is placement, ie you can manually place the inverters far away (and fix their location) which would give you long delay because of routing. You can also try directed routing but this is more complicated.
@vinayak_sasken123
You will need to use some custom logic to add delay between two components. Please provide more details on design spec/requirement for us to provide relevant suggestion.
Anusheel
Helpful answer -> Give Kudos
Hello Anusheel,
I am using ring oscillator to generate clock/square wave and I have written small logic to measure frequency of this clock.
Ring oscillator design is attached to this email.
I want to add big wire between two inverters and measure the change in frequency for that purpose I want to add big wire delay between two inverters. Is there any way for it?
Hi @vinayak_sasken123,
You can use timing constraint such as set_max_delay to guide the tool.
Arpan
