AR
Initialising BRAM using $readmemb?
Hi, I'm trying to make vivado infer BRAM to store data from two external data files, I've tried using ram_style, I tried using the language template and I've read nearly all the AR's regarding readmemb/h. I feel like I'm missing something obvious or maybe this isnt possible? Thanks in advance! P.s. using verilog and vivado 2020.1
(* ram_style = "block" *) reg [7:0] imageArray [0:783];
(* ram_style = "block" *) reg [7:0] patternArray [0:63];
initial
begin
$readmemb("284in1.mif",imageArray, 0,783);
end
initial
begin
$readmemb("pattern.mif",patternArray, 0, 63);
end
varunra
Hi @AR
I have gone through the code. all the RAMS are read asyncly, so vivado will infer distributed ram.
varunra
I tried the above of usage, i didn't see any issue with vivado 2020.1 , it inferred 2-BRAM. and read the mif files successfully. can you clearly mention the issue you are facing?
or paste the complete code so that we can debug?
**Just make sure that you are using SYNCHRONOUS read. if not vivado will infer distributed ram
Varun Raj
viviany
Below is from UG901. To infer a BRAM as a ROM (storing data in BRAM), you also need the coding in red rectangle to describe the BRAM read/write behavior.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
AR
Thanks for the reply, I'm not sure how to check if i am using sync read? The problem I am having is that LUTRAM/LUT is being inferred but I'm over utilized in these areas, if i can get the data to be stored in BRAM it would save some room for me.
AR
I'm trying to infer the ram in the top module of my design, the entire module >1000 lines is based on the data being read into the top module, i would have to rewrite a lot of code to make a separate module I think, Thanks.
varunra
Can check if reading data from ram, is it under clock? if not move it to always @(posedgeclock). that should work
AR
Tried that and still the same result! is there a min size the data needs to be for bram? Currently at 22*784 so 17248 bits. Ive seen 18k and 36k so do i need to make my array a bit bigger?
varunra
Hi, it possible to share the code?
AR
I'm using the code in the link below, I've altered sizes etc. but no major changes, CNN.v is where I'm having the issue. https://github.com/AniketBadhan/Convolutional-Neural-Network
AR
This is the all I have changed at the beginning.
`timescale 1ns / 1ps
`define IMAGEROW	28
`define IMAGECOL	28
`define PATTERNROW	8
`define PATTERNCOL	8
`define FILTERROW	3
`define FILTERCOL	3
`define CONVROW		26
`define CONVCOL		26
`define MAXROW 		21
`define MAXCOL		21
(*use_dsp48="yes"*)module CNN (//(*use_dsp48="yes"*)
	input clk,
	input rst,
	output reg [3:0] numberOfTimes_PatterDetected
	(*ram_style="{ block}"*)reg [7:0] imageArray [0:783];     //imageximage									//memory buffer for storing image and the convolution of it with the laplacian filter
	(*ram_style="{ block}"*)reg [7:0] patternArray [0:63];	   //patternxpattern								//memory buffer for storing pattern and the convolution of it with the laplacian filter
	(*ram_style="{ block}"*)reg [21:0] stage2Output [0:783];  //imageximage
	(*ram_style="{ block}"*)reg [21:0] stage3Output [0:195];   //1/4 imageximage
always @(posedge clk) begin
 $readmemb("284in1.mif",imageArray, 0,783);	//899	//16383	//reading image
end
 $readmemb("pattern.mif",patternArray, 0, 63);    //patternxpattern
end
varunra
Hi @AR
AR
Thanks for taking the time I appreciate it!
maheng
请问这个问题最后怎么解决的?
