Keeping port name same after synthesis.
  After synthesis i write out the verilog netlist "FILE->export->netlist". Vivado inserting  an escape character(\) on top module entity.I like to keep the same name on top level entity after synthesis without inserting any character. (Vivado 17.4)
Netlist.v
  input [15:0]\reg_wr_arr[1023] ;
  input [15:0]\reg_wr_arr[1022] ;
  input [15:0]\reg_wr_arr[1021] ;
  input [15:0]\reg_wr_arr[1020] ;
  input [15:0]\reg_wr_arr[1019] ;
  input [15:0]\reg_wr_arr[1018] ;
  input [15:0]\reg_wr_arr[1017] ;
  I already tried these option ,but nothing works.
              1. flatten_hierarchy = none
                 directive          = Default
             2. Keep_hierarchy @ module level (in RTL)
             3. Don't touch constraint in .xdc
             4. @ Entity :
                attribute dont_touch : string;
                attribute dont_touch of tx_top : entity is "true|yes";
Is there anywhy to keep the port name same for top level entity after synthesis as well as P&R.?
-GR
Mentor
Mentor
It might be simpler to  edit the file and do a global replace of the "\" character with " ".
