Latch problem in a simple CPU project
Hey everyone!
I need quick help for my project of a simple CPU unit. It generates latches for all registers and i can't figure it out. I generated the scheme and the permit signals are connected only for 3 registers while in the code i connected every register in the same way
Here's a pic of that part of the code: https://imgur.com/a/7DxdM
As you can see registers 1 2 3 are done in the same way a as register 4 (also others), but they are the only 3 that work. I generated a schematic and it shows only those 3 are connected from the CU - oWE to the permit signal of those 3 registers - iWE
There's a zip also with the project if someone is willing to take a quick look :)
In the CU.vhd file, you didnt assign the outputs in the IDLE state. This will created latches for all of the select lines.
