Visitor shubhamn
License Error while synthesis in Vivado2017.2
Hi, I have installed Vivado2017.2 in windows10, in License Manger I have set the path for XILINXD_LICENSE_FILE and LM_LICENSE_FILE. I believe that my Vivado License is loaded correctly. I have checked that my host id also matches. Then also I am getting below ERROR:
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7k325t-ffg900'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
Can someone please help me to resolve this ERROR.
Scholar hbucher
Re: License Error while synthesis in Vivado2017.1
Did you check the license manager (Help/License Manager...) for the status for all synthesis?
you must have license to use this device. Check your license file by opening in any word editor . You can manually. In case you have valid license it may not setup correctly
check this link to debug this issue at your end
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html
Thanks and Regards
Balkrishan
Which license you are using? Webpack/ device locked/ system edition?
Are you able to synthesize any other example design targeting any different FPGA?
Can you share license and environment report through personal message?
To generate environment report run command: report_environment -file <path of file>/env.txt
Yash
@shubhamn,
Do you have a webpack license? Webpack license won't be sufficient to use this device.
If you have installed a purchased license, can you try closing "all" Xilinx applications and restarting Vivado?
Nupur
Visitor shubhamn
Hi below I have attached a screenshot of Vivado license manager. I have set XILINXD_LICENSE_FILE=C:\.Xilinx;D:\Xilinx\Vivado\2017.2\data\ip\core_licenses.
@shubhamn,
These are all IP licenses. Run this command in Vivado tcl console and share the env.txt file:
report_environment -file env.txt
Did you purchase a board? If yes, you must have received a voucher with it. You can activate it using steps given here: UG1042
If you have not purchased a board and but are trying to use the device you mentioned, you need to purchase a license: buy
If you do not wish to buy a license, then you can't use the device mentioned above.
However, you can install Webpack Edition of Vivado(selected during installation) which is free. But you will only be able to use these devices:
Nupur
Visitor shubhamn
@nupurs please find the below attached env.txt file.
@shubhamn
You have no Vivado license installed.
Can you try closing "all" Xilinx applications and restarting Vivado?
Nupur
Are you seeing issue with Vivado 2017.1 or 2017.2 . Your title says Vivado 2017.1 but in attached env.txt only 2017.2 . You can open the .lic file and see if you have valid license. You must have permanent license . Webpack or design linking license will not work for your target device
Thanks and Regards
Balkrishan
Visitor shubhamn
@nupurs
I have restarted Vivado then also I am getting same error. In License information in env.txt file synthesis is not included as feature. I think I have not added path for this. Could you please tell me how include path for this?
open license manager and set license path
Thanks and Regards
Balkrishan
Visitor shubhamn
@balkris
In vivado license manager I have set
Then also it is showing same error
@shubhamn,
What is the location of the Xilinx license that you just installed?
Nupur
Visitor shubhamn
@nupurs
Location where I installed my license=D:\Xilinx\Vivado\2017.2
@shubhamn,
then add this path to XILINXD_LICENSE_FILE: D:\Xilinx\Vivado\2017.2
Close all Xilinx tools and restart Vivado
Nupur
Visitor shubhamn
Hi have tried this then also I am getting ERROR.
@shubhamn
Try restarting your system.
Generate and share the env.txt again.
Nupur
Visitor shubhamn
@nupurs
Restarted my system. I cannot find synthesis feature in env.txt file in License information section I think this is creating problem.Generated env.txt file. Please find it below:
@shubhamn,
The XILINXD_LICENSE_FILE is still set to
Please modify it to:
C:\.Xilinx;D:\Xilinx\Vivado\2017.2\data\ip\core_licenses;D:\Xilinx\Vivado\2017.2
Nupur
Re: License Error while synthesis in Vivado2017.2
Hi @shubhamn
There is no Vivado tool license reported in the Xinfo you have shared, you have only IP licenses. Hence you need to purchase a new license for device you are using as it is not supported by webpack.
Rohit
Rohit
