Logic getting trimmed
I am trying to migrate design from Vivado 2018.2 version to 2019.2 version. I have upgraded all Xilinx IP's in the design instead of re-configuring and regenerating it.
In the synthesis netlist, I see that 90% of the logic is getting trimmed in comparison to the 2018.2 version.
The only change in design is the up-gradation of IP's.
What could be the possible cause of this?
Saket
Re: Logic getting trimmed
How did you know 90% logic was getting trimmed? By looking at the Synthesis utilization report?
Where did you check the Utilization report?
This AR may be helpful for your question:
https://www.xilinx.com/support/answers/59282.html
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I checked the --- Report Instances Area Table in the runme.log of the synthesis.
Saket
And compared with the same part in synthesis runme.log of 2018.3?
-vivian
Hi @viviany
Yes Compared the same with 2018.2 version.
Saket
Can you provide the two Synthesis log files?
-vivian
