Anonymous
Not applicable
MIG IP OOC Synthesis never ends
Hello Everyone,
I have problem with MIG IP ooc sysnthesis process. Here is what I've chronologically experienced about the problem;
I have
Step1: integrated the MIG IP into my design.
Step2: synthesized the IP (in ooc mode) and the design code.
Step3: loaded the bit file to target and observed the phy has active (means phy_init_done is Logic-1)
Step4: integrated ILA to see the internal signals (SDR user interface IP control signals)
Step5: synthesized again and changed the ILA signals (I've added the address and data signals)
Step6: synthesized again
Step7: observed that ILA dashboard has not opened.
Step8: reset the synthesis by right clicking to "Run Synthesis" button.
Step9: (same condition Step7)
Step10: Step8 + reset  all ooc module synthesis
Step11: started the ooc sysnthesis again (without overall design synthesis)
Step12: got the follwing error:
Step13: put the following tcl command to overcome the problem and it worked;
             set_param synth.elaboration.rodinMoreOptions {set rt::extractNetlistGenomes false}
Step14: run the synthesis again. And, synthesis never ends right now (by the way, I've checked the license, and there is no problem with it).
I've thought that something gone wrong in the project setting or somewhere. And I created a new project.
I've only added the MIG IP into the new project and started the synthesis. Problems goes on..
Any suggestion for this problematic situation?
Thanks in Advance,
Batu
Re: MIG IP OOC Synthesis never ends
@Anonymous
Not sure on why IP synthesis didn't work in 2016.2 for your machine. Good to hear that with 2016.4 you are able to complete OOC synthesis. Please close this thread by marking appropriate answer as "Accept as solution" .
Anusheel
Helpful answer -> Give Kudos
@Anonymous
Did you test this flow in 2016.4 instead of 2016.2? Also, share the OS information.
set_param synth.elaboration.rodinMoreOptions {set rt::extractNetlistGenomes false} -- Did you get this param from Xilinx?
Anusheel
Anonymous
Not applicable
@anusheel
OS of my computer is 64bit win7-enterprise edition. Our IT department has rebuilt my computer. And now I'm using 2016.4 version without any problem.
I have no idea what was wrong on my computer.
Best Regards,
Batu
@Anonymous
Anusheel
