sapan533
Mapping signal names before and after synthesis
I want to know if there is any way by which we can have the mapping between signal names before and after synthesis?
I want to have the mapping between RTL signals which is input to Vivado Synthesis and the signals in synthesized netlist.
Rgds
Sapan
nupurs
Apply DONT_TOUCH property. Refer to this link for details:
http://www.xilinx.com/support/answers/57727.html
Usage of DONT_TOUCH is as follows:
Verilog Example
(* dont_touch = "true" *) <signal_name>;
VHDL Example
attribute dont_touch : string;
attribute dont_touch of <signal_name> : signal is "true";
Accept as solution if it resolved your query, give kudos(star on left) it it led you to the solution.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
arpansur
Hi @sapan533,
You can make use of hierarchical filter and * to use in XDC before synthesis.
For e.g;
[get_cells -hierarchical -filter { NAME =~  "*ibufds_instQ0_CLK1*" } ]
can be replaced with
[get_cells mgtEngine/gt_usrclk_source/ibufds_instQ0_CLK1]
You can also go through the following link
http://www.xilinx.com/support/answers/62136.html
Arpan
Arpan
sapan533
@nupurs
This wont be a perfect solution as it will require me to change RTL everywhere. I am looking to use this mapping during readback. And i want to map the signal names in logic location file to that in the RTL.
RGds
Sapan
dwisehart
If you set -flatten_hierarchy in the Synthesis settings to 'none' you will be a lot better off because the names won't change. I usually find that I get better timing with it set to none as well.
Daniel
sapan533
@dwisehart
Hi Daniel,
Thanks for the answer. That sounds a better option than others. But if we do not set flatten_hierarchy to NOne, is it still possible to have the signal names mapping from Vivado? I am sure there must be some way to get this information.
RGds
Sapan
dwisehart
Not that I am aware of, Sapan, and I have looked for this type of functionality.
Daniel
