Migration from Vivado 2017.4 to 2019.1: strategy is locked
Hi all, I am starting with project migration from Vivado 2017.4 to the 2019.1 version. Upgrade of Ips was successfully done.  I have two problems/questions:
1) why I am not able to change stragey (options are locked):
2) How I can change Synthesis 2017 to the newer version?
Thank you in advance!
Hi @kvantum.nuly,
What do you mean by locked? I have tried at my end and i am not facing this issue. Can you please elaborate your steps?
Just click on that synth run and click on options (in synthesis run properties window)  where you will see the options to select different strategies.
You can also set it via tcl commands as shown below.
set_property flow {Vivado Synthesis 2019} [get_runs synth_1]
set_property strategy Flow_AreaOptimized_medium [get_runs synth_1]
hemangd
Hi @kvantum.nuly,
hemangd
