moon5756
Out of context module synthesis removed from Design run tab
le'ts say I have module
module top(input in_0, in_1,
                   output out_0, out_1);
    func_0 function_0(in_0, out_0);
    func_1 function_1(in_1, out_1);
endmodule
module  func_0 (input in_0,  output out_0);
    // empty
endmodule
module  func_1 (input in_1,  output out_1);
    // empty
endmodule
First, empty out the contents. Then, synthesize top, func_0 and func_1 out of context.
Then, read synthesized func_0 checkpoint and func_1 checkpoint from top checkpoint.
Here, do I need to re-run top-level synthesis once I read_checkpoint two func_0 and func_1 netlists, or
can I go to opt_design stage?
Thanks!
thakurr
Hi @moon5756
In addition to @jmcclusk comments, if are you trying to use this synthesis checkpoint to open somewhere else then you can open the synthesized design and do write_checkpoint. This check point will read both ooc checkpoint along with top level checkpoint.
Now you can open this checkpoint and proceed to opt_design phase of impl.
Rohit
Rohit
jmcclusk
Mentor
Mentor
you should be able to proceed to "opt_design" after reading in the out of context module checkpoints, provided that you've put black box attributes on the empty modules, so they aren't optimized away.   At least I think you need black box attributes...  it might actually work.   Let us know if they are needed.
thakurr
Hi @moon5756
Rohit
Rohit
