ppereira
Primitive not supported
Hi There,
I have created a simple module that has 8 inputs and 8 outputs - it uses one primitive (8 inputs 1 output) for each output. When simulating all goes well, but when I try to synthetize Vivado throws me the error: "[Synth 8-27] primitive not supported". What am I doing wrong? Can't I build a module that uses primitives? In C this is simply a 256 bytes array.
hemangd
Hi @ppereira,
Yes, it will be better if you go with behavioral code using case or if else statements.
hemangd
Close this thread, if you do not have further queries on it.
hemangd
bruce_karaffa
Does Vivado tell you which primitive isn't supported? Which FPGA  are you targeting?
hemangd
Hi @ppereira
What primitives are you using?
Are you using User Defined Primitives? Check this thread for it. https://forums.xilinx.com/t5/Synthesis/Synthesis-failing-on-user-defined-primitive/td-p/436000
hemangd
hemangd
ppereira
Thanks for the link. Yes - it's a user defined primitive. I think I will be better of with a case statement for the whole table. It will be simpler and perhaps Vivado deals with it better.
ppereira
I am targeting Artix-7. I have reduced from 8 primitives down to only one to test Synthetize, but it doesn't work either. I will go with a case statement for the table and check if Vivado doesn't complain on synthetizing. Thanks for the reply.
hemangd
Hi @ppereira,
hemangd
hemangd
