Question for error [Synth 8-439] module '' not found.
Hi, I got a problem about [Synth 8-439] module 'CLOCK' not found.
However, I already inserted a 'CLOCK' module under the 'TOP_LDPC_Decoder' module.
Everyone can check this through above images.
How can I fix this problem? Can anyone helps me? Please..
Mentor
Mentor
Re: Question for error [Synth 8-439] module '' not found.
your clock module is for simulation only, not for synthesis...   The error you are getting indicates an error in synthesis.  You should remove the simulation modules from the design sources to be synthesized (see the file properties window).
Mentor
Mentor
