Visitor carlmgmt
Register clock enable synthesis/implementation on Vivado
Hello.
I'm using Vivado 2014.4 for design implementation of VHDL code on a Artix-7 FPGA (XC7A35T CSG324-1). I see what I think it's a odd way of synthesizing registers with clock enable (default options are used for synthesis and implementation).
A simple code for a 1 bit register with clock enable as:
  library IEEE;
  use IEEE.std_logic_1164.all;
  use IEEE.numeric_std.all;
  entity top is
      port (
        clk_i        : in    std_logic;
        en_i        : in    std_logic;
        data_i     : in    std_logic;
        data_o   : out  std_logic
  end entity top;
  architecture arch of top is
  begin
    process(clk_i)
    begin
      if (rising_edge(clk_i)) then
        if (en_i='1') then
          data_o  <= data_i;
        end if;
      end if;
    end process;
  end architecture arch;
generates a FF+LUT. FF clock enable input is not used (set to 1) and input data to register is created based on en_i, data_i and register output data_o.
Attached you can see schematic of final circuit (after implementation).
Am I missing something? Do you know whether any option/constraint should be used for clock enable inference?
Best regards,
 Carlos
Re: Register clock enable synthesis/implementation on Vivado
Use DIRECT_ENABLE attribute on the input.
Apply DIRECT_ENABLE on an input port or other signal to have it go directly to the enable line of a flop when there is more than one possible enable or when you want to force the synthesis tool to use the enable lines of the flop.
The DIRECT_ENABLE attribute can be placed on any port or signal.
Example
entity test is port(
in1 : std_logic_vector (8 downto 0);
clk : std_logic;
ena1, ena2, ena3 : in std_logic
out1 : std_logic_vector(8 downto 0));
attribute direct_enable : string;
attribute direct_enable of ena3: signal is "yes";
end test;
Anusheel
Helpful answer -> Give Kudos
Example
clk : std_logic;
end test;
Anusheel
Visitor carlmgmt
Anusheel, many thanks for your quick reply.
 Carlos
Visitor filgiorgi
Thanks, I didn't know how to force tha use of CE.
Anyway, if it may be of some help, the synthesis tool seems to be reluctant in using CE when the datapath of D is a loopback combinatorial logic of Q, as I see from the schematic you posted. I just made a post here about that.
https://forums.xilinx.com/t5/General-Technical-Discussion/using-clock-enable/m-p/776338#M39599
F.
Observer josyb
Actually the OP's original post only has a feed-back from Q to D, because Vivado didn't implement the CE
I stumbled on the same issue while I was looking for a strange generated loop (output of LUT back to input). While expanding the schematic around that I noticed that Vivado doesn;t always implement a CE where I expected it to.
