omlika
Report all cell delays of given part
I want to compare cell propagation delays of different devices. Is there a Vivado command or a text file I should look at to get this information.
Is it possible to obtain the delay for the worst and best corners?
hemangd
Hi @omlika,
If you are looking for the absolute delay of the particular logic element/cell for a device part, it will be available in the speed files of respective primitive cell.
 You can use below command to get speed file values “get_speed_models”.
i.e. :  report_property –all [lindex [get_speed_models –of [get_bels SLICE_X95Y110/A6LUT}] 0]     ---- This will get the speed files for LUT.
What you will concern here is SLOW_MAX and SLOW_MIN.
Fast process corner means worst case PVT {lowest voltage and highest temperature}
Slow process corner means best case PVT {highest voltage and lowest temperature}
For more information you can write tcl command get_speed_models –help , get_pips –help & get_wires –help.
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
hemangd
Hi @omlika,
hemangd
hemangd
